Old 11-29-2011, 06:57 AM
rasorinc rasorinc is online now
Rep: 687 Posts: 1,175
UN designed boats--Dept. of Fisheries
I do not know where I found these designs for 4 boats sized 5.2m, 6.3m, 7.4m, 8.5m but I'm posting them as some might wish to build one of these. Plans are very complete-all frames drawn out and all connections drawn out. Also complete material lists, how to widen beam, very thorough. Inboard, or outboard or row. ENJOY.
http://www.fao.org//docrep/007/y5649e/y5649e00.htm
Old 11-29-2011, 06:58 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
UN tries to get their fingers into everything.
The 8.5 M boat is nice.
Hoyt
Old 11-29-2011, 07:02 AM
Rep: 670 Posts: 2,457
Sure...they have been around a while. Nice boats and nice construction details. Great boats for low power home builders.
Old 11-30-2011, 01:08 PM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
Depth & draft ??
The 7 & 8 meter boats have drawing errors or they are for floating in 16" 0f water. 700 K boat carries only 400 K of cargo ??
I can be the Grand N A at the UN any day.
Old 11-30-2011, 04:49 PM
thedutchtouch thedutchtouch is offline
Rep: 39 Posts: 90
click on the fisheries logo and type boat design into the search, then click on the documents tab and you'll find a few more for trawlers, metal boats, and an older wooden boat one, i printed out all 4 to add to my library. (sorry couldnt get direct links to the PDF or search results to work)
Old 12-01-2011, 10:36 AM
Rep: 749 Posts: 1,314
Several years ago there were some detailed experiments to determine the most practical sail types for various boats common in third world economies. I think that it was this same agency who sponsored that research.
Old 12-01-2011, 11:45 AM
Hi, the only other boats Icould find were a small open one and a ferro cement. How did you find 4 more??? thanks
Old 12-02-2011, 01:30 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 196 Posts: 707
where is their plan for "lifting propulsion system for beaching on the East Coast of
India"?
In the 3megbyte 77pg download they seem to show both multi-planked bottom and plywood construction, or it is planks THEN plywood?
Too bad they don't have a plan for lee-boards to make it a proper sailer.
The "emergency sail" and "shelter for crew" use of the same tarp is sort of what I had in mind for my all purpose mini-motor sailor sport and work boat, except I was also thinking of a tarp suspended much higher for comfortable head room during rain.
how about a 25hp outboard on a planing sailing dingy?
Old 01-12-2012, 03:12 AM
BPL BPL is offline
Rep: 115 Posts: 154
Good link rasorinc.
The date says 2004/2005 for revision 2 and 1997 original but I believe these plans are older than that.
Also found this old FRP manual from 1991 http://www.fao.org/DOCREP/003/T0530E/T0530E00.htm#TOC
and this http://www.fao.org/docrep/field/003/...251E00.htm#TOC
I was unable to find the FAO metal boat plans thedouchtouch referred to above.
Old 01-18-2012, 12:08 AM
Rep: 572 Posts: 646
I do agree, very seaworthy small boats, working with very little power. The 8.5m can work with a small chinese diesel like the Changfa of 10 HP, thus the boat is very economical for coastal fishing with a useful speed. These boats can also be made without mold from polyester plates. (the placoplastic system).
These boats originated in the sixties and have had a long evolution. Another boat was designed from a small Philippine fishing boat and that became the panga, very common in Latin America, as Yamaha diffused the plans for cheap construction in polyester (Inmemsa in Mexico and Eduardoño in Colombia made thousands of them) and Yamaha sold thousands of 2 Stroke outboards of the Enduro line...
Old 01-18-2012, 12:10 AM
Rep: 572 Posts: 646
Surely you won't never be a NA in any place. Your comment shows that you have not any knowledge of the subject...look again at the boats and their purpose, and use your brain. Happily øyvind Gulbrandsen is a true NA.
Designed to go anywhere. mohawk Jet Drives 0 09-11-2011 03:50 PM
Who could have designed this yacht? Leonardo Motorsailers 26 07-16-2011 08:47 PM
Self Designed Yacht TheMoodyMonk Boat Design 42 08-20-2010 02:24 PM
Yacht Construction Manager and Dept. Managers Needed tricon Services & Employment 0 12-18-2008 07:44 PM
Artisan fisheries in Africa Gilmarine Fiberglass and Composite Boat Building 0 09-01-2004 07:04 AM
