Old 05-10-2011, 01:43 PM
claydog claydog is offline
Rep: 37 Posts: 41
Twin VS single
I've searched the forum and come with a lot of conflicting information, and not having anywhere near the math skills and overall boat knowledge needed to figure it out for myself, I’m hoping for some help in understanding the pros and cons of a twin engine set up beyond cost and having a backup in case of failure. My question is, is there any performance gain on a twin engine set up over a single, assuming all other variables are the same on a planning hull boat?
Thanks Andy
Old 05-10-2011, 03:43 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Claydog,
It depends on how you define performance, but there are some advantages each way.
A single engine set up has
1) less stuff in the water and therefore reduces drag from the second engine.
2) Less installed weight for the same horsepower (Older boats may not be able to handle the weight of twin modern engines)
3) Half the maintenance (since half the number of engines)
4) Less dollars/hp (generally, even with a kicker)
A twin set up
1) allows differential stearing (unequal thrust) greatly enhancing low speed manuverability
2) More options in installing location allowing for better balance
3) Less weight and thrust at a specific point
4) Better hole shot (low end torque)
5) No Torque stearing
6) Less prop ventelation (Not on centerline)
In short there is no one size fits all aproach to selection. But for me, the one advantage you excluded (as a back up engine) is the most important. I fish off shore as far as 45 miles in a 26' open cat. Knowing if I loose one engine (I amso have two seperate fuel tanks, and isolate the engines from one another electrically) I can still get up on a plane with one engine and make it back in something like a reasonable amount of time is very important to making these trips safely,.
Old 05-10-2011, 04:27 PM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
In addition to Stumble's observations:
For the same speed the total engine power of a twin-engine boat will be higher than the engine power of a similar (same EHP) but single-engine hull. Various authors claim various percentile increase, ranging from 15% to 30%, depending on hull type and speed.
The difference lays in the fact that a twin-engine installation will have smaller propellers (which are less efficient) which, in addition, won't benefit the influence of the hull's wake. It will also have a higher drag due to double propeller struts, shafting and (eventually) double rudders. Furthermore, two smaller engines will be somewhat less thermodynamically efficient than a single big engine.
Cheers!
Old 05-10-2011, 05:15 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
i run twins, this is the first twin engine boat i have owned and the last. the handling is good but not good enough to out weigh the negatives. the 2 biggest for me are having to buy 2 of everything and very inefficent, 450 hp when the same model boat is faster with a 260 hp sterndrive.
brendan .
Old 05-10-2011, 05:30 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
The fastest boat in the world has a single engine. Steve
Thanks Andy
Old 05-10-2011, 05:36 PM
daiquiri's Avatar
2x225 HP engines + stendrives weigh around 800 kg + fuel
1x260 HP engine + sterndrive weigh around 450 kg + fuel
Considering that the weight is a single most important factor in planing boat power requirements, it's no wonder that you have lost performance.
A more correct powering for your boat, imho, if you wanted to change to twins, would have been 2x(160-170) HP, which would weigh around 550-600 kgs. Still much more than a single engine + sterndrive, yet much less than your actual configuration.
Old 05-10-2011, 06:15 PM
Rep: 247 Posts: 655
the twin 225 chryslers are standard in my old 70's boat, they are shaft drive which also contributes to the equation. the ones that have been refitted with 260 sterndrives perform a lot better. my boat is over 4 metric tons. i just think twins are to much to look after, i would rather look after one engine .
brendan .
Old 05-10-2011, 07:24 PM
u4ea32's Avatar
u4ea32 u4ea32 is offline
Rep: 175 Posts: 378
I agree that twin engines can be a bad idea, for all the reasons mentioned. My current boat is also my first and last twin engine boat.
A big reason twin engines are a big fail in most boats is the lack of access for inspection, maintenance, and repair. Therefore, the maintenance costs are much more than double due to the great increase in hassle to do anything. Therefore, the likelihood of failure is much greater, because for a given amount of money you can only afford so much maintenance, so some maintenance will not be done, and some failures will occur.
Very few commercial boats have more than one engine. Including the Sea Tow boats. The key to their ability to cross oceans, fish far offshore, and to rescue recreational boaters, is the ability to maintain their vessels and powerplants.
Most recreational boats are not designed to be maintained, even single engine boats. Most recreational boats are designed to be bought and sold. This directly leads to that old saying about the best days in the life of a boat owner is the day the boat is bought, and the day the boat is sold. Only on those two days is the boat actually doing what it was designed to do.
David Smyth
Old 05-11-2011, 09:43 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
daiquiri,
Unless it's a flat bottom the twin can run larger props w the same draft.
There is no prop walk that the rudder must constantly correct for = less drag.
Two smaller shafts should be about the same drag as one big shaft.
What does this mean? "won't benefit the influence of the hull's wake."
The twin is more expensive and has more vulnerable props but other than that I see twins as superior from a performance standpoint. But I know my opinion is not shared by most. I see the prop walk issue a huge advantage to the twin.
Old 05-11-2011, 12:02 PM
Rep: 37 Posts: 41
Thanks to all, this tread has helped me a lot in understanding the pros/cons of twin engines.
stumble, the only reason I exclude the second engine as back up is that it is the most obvious benifit. It's also my prime reason for considering a twin, I don't get as far out in the great lakes as you do in the gulf, but I do have to run into any weather that pops up to get back to port.
Old 05-11-2011, 12:11 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
I've searched the forum and come with a lot of conflicting information, and not having anywhere near the math skills and overall boat knowledge needed to figure it out for myself, I’m hoping for some help in understanding the pros and cons of a twin engine set up beyond cost and having a backup in case of failure. My question is, is there any PERFORMANCE GAINS on a twin engine set up over a single, assuming all other variables are the same on a planning hull boat?
Thanks Andy
No, only losses.
-Tom
Old 05-11-2011, 03:18 PM
Claydog,
As you can see the jury is split on the issue. Personally I have owned, and would own in the future both set ups. For off shore work the marginal efficiency losses from a twin are more than made up for with the added safety. And if eeking out the last possible MPG is critical then slow down 10% and in any configuration you will save money.
That being said for inshore work on smaller boats I prefer the simplicity of a single engine.
I don't think one is necessarily better than the other, Ijust think they have different purposes.
Old 05-11-2011, 06:22 PM
Rep: 247 Posts: 655
the most common setup here in aus is an auxillary outboard on the transom for back up. stumble , i can see your point but i am convinced that 1 well maintained engine won't let you down .
brendan .
Old 05-11-2011, 06:38 PM
Pierre R Pierre R is offline
Rep: 458 Posts: 461
The first twelve post on this thread are some of the best that I have seen on this topic yet.
Old 05-11-2011, 06:39 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
In a performance boat its the drag that kills you
Just look at rigs that have 3 outboards instead of 2
What you can gain in a heavy boat adding an engine is getting the same cruise speed but with lower engine rpm and that could make a big difference in fuel consumption especially with automotive engines.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Cat Centerboards Single vs Twin. Zed Multihulls 31 02-13-2010 03:02 PM
Twin inboard to single i/o repower goodidea28 Powerboats 2 08-19-2008 12:43 PM
twin single keel Garth Boat Design 5 08-18-2006 05:21 PM
Single Inboard To Twin Outboards RYANPO Boat Design 7 07-20-2006 05:07 PM
twin engine/single rudder? Guest Boat Design 3 05-18-2003 09:19 PM
