Old 07-11-2011, 12:05 AM
ecoearthyacht ecoearthyacht is offline
Rep: 10 Posts: 2
twin nkeel sailboats and rudder design
I have a tylercraft 26 sailboat with 30 draft twin keels and small aft rudder. The boat is 26 ft, by 8 ft beam, and is on a trailer. THe boat spins 180 degrees when on a broad reach with a following sea. Otherwise the boat points and performs well on other points of sail. I believe the small rudder, with rounded lower fore leading edge and aft trailing edge somehow is the problem. What rudder size and shape and possible skeg in front of rudder would cure this tacking problem? I can send photos to someone who knows the design issues to advise me . Thanks for the help TIm at ecoearthyacht@yahoo.com
Old 07-12-2011, 03:10 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
You could get an engineer to calculate the suitable areas for a reasonable fee.
I am using a very competant one who is active on these forums to design a 28ft, twin board trailer sailer, and he was able to advise me on the correct sizes of rudders and keels, and more importantly, work out if the boat was unbalanced in sail plan, centre of effort etc.
I will put you in touch if you think that is the way to go.
Old 07-12-2011, 07:41 AM
Rep: 1493 Posts: 7,447
The rudder is probably ventilating. A common solution is to have a rudder that can be lowered.
Old 07-12-2011, 11:56 AM
Rep: 10 Posts: 2
to rwatson twin keel rudder issue
Please contact me if you would re the rudder design issues on the twin keel tylercraft 26. I am at ecoearthyacht@yahoo.com Thanks I would llike to hear about your boat design and project. TIm
Twin screw, rudder placement Landlubber Inboards 8 05-04-2008 04:15 PM
Twin engine, twin rudder and doors on a sailing yacht Arvy Boat Design 9 10-23-2005 10:20 PM
Twin Rudder Scantlings mishnish Boat Design 5 11-09-2004 11:11 AM
Design Questions for 16-20 foot sailboats Garrett Sailboats 8 10-19-2004 02:16 PM
twin engine/single rudder? Guest Boat Design 3 05-18-2003 09:19 PM
