| twin engine/single rudder? would it be possible have a twin engine / single rudder configuration installed on a skeg motorboat /lobster boat?how would this affect steering? |
| I am doing this on a 37 ft sailboat. The con is there will be no prop wash assistance to the steering for maneuvering, but the pro is the rudder sees cleaner water... |
| With twin engines the rudder is only for trimming. You'll steer and maneuver with the throttles and shifters.
__________________ Gonzo |
| A single rudder behind the skeg in a twin screw boat is satisfactory if the rudder area is the sum of the normal twin rudders. You will get stream effect at the boat speed, instead of the higher advance flow speed escalated by the propeller helice. The rudder type will follow the unbalance type. While the balanced rudders can be installed behind the propellers. So you will need a larger steering gear. Peter |
| Newport 27 Rudder?? | MrJunk66 | Sailboats | 33 | 08-03-2009 08:09 PM |
| Pros and Cons of Transom Hung Rudders | Gone Ballistic | Sailboats | 19 | 09-19-2005 09:15 PM |
| Rudder Design and Broaching | joebobb | Boat Design | 0 | 02-25-2005 10:43 PM |
| Twin Rudder Scantlings | mishnish | Boat Design | 5 | 11-09-2004 12:11 PM |
| New Rudder verses Old Rudder | Cliff Ruckstuhl | Sailboats | 0 | 03-06-2004 04:36 PM |
