| turny transome , beach cat working on a design to keep the rudder , a rudder and not a elevator
__________________ if its perfect its sound , if its sound its perfect |
| Simple, stop leaving the the sail hoisted on a blustery day on the beach. |
| thanks for the tip ![]()
| Matt; Why? When you are flying a hull you are somewhere around 12 degrees heel. The lift component resulting from that angle is not a big one. More than that, the small lift. when the rudder becomes a partial elevator, could be advantageous if you utilize it imaginatively. |
| you know Im kinda new to this sailing thing , so new I have yet to sail my own boat . but I like reinvent things . Sooooo. I would imagine flying a hull would be a lot like driving a car on two wheels . the wheels pushing into the ground , turned in one direction if only the boat or car steering could go from car to motor cycle steering . plum of the steering device, keeping it a turning device at all crafts inclination angles . there are much better and safer ways of creating lift . but keep the rudder operation and elevator separate please . one would think the lift would be good, but if turned the other way would push the front end into the water and pitch pole ( I believe they call it ) boats in many ways operate on one dimension, unlike a plane that flys in two dimension and a helicopter in three dimensions a rudder needs to stay a rudder on a boat
| That rudder is broken, right? I don't understand what you're asking. |
to be done to be called a complete turny transom . pin-dulum the top pin pivots on one L/R axis , as does the rudder preforms its normal operational pivot dulum I still need to complete the guide rail so the bottom pin locks and slides to different angles disclaimer : no rudders were harmed in the taking of this photo
| Matt; you are wasting your time on this project. The benefit derived from your thoughtful work will not amount to any measureable increase in performance. Ask yourself why would world class, megabuck, ultimate high tech, cats not use a similar scheme if there was merit. The boat is unlikely to pitch pole if you turn the rudder downwind rather than upwind. It is subject to pitch pole if and when you are traveling at speed into waves whose period can allow the boat to jump over one wave and stick its nose into the next wave. This is usually the result of burying the lee bow. I will regale you with the facts about motorcycle vs automobile cornering ability in another post. Keep thinking, but keep in mind that there is no need to re-invent the wheel. |
| funny as an inventor Ive heard that more than once , I will say though the wheel will never be finished as materials/tools tec. and humans advance so will the wheel. driving around on wood and metal wheels . naaysay: go tell a tire company "stop reinventing the wheel" it has already been invented . you will sound more like a jack ass than stud. then drive off on into the sunset on wood / steel wheels pulled by a horse. I kinda think I have a grasp on how some things work and think its time for the rudder to be reinvented. peace and my your transom someday turn on a perfect plumb angled rudder.
| dear mods of boat design .net, no need to redesign boats because every thing has already been invented so no need for this forum
| No offense inended, Matt. I am guilty of making a faulty assumption. I assumed that you posted to get some feed back from others who have extensive experience with boats. Peace and "may the force be with you". |
| no offense taken , more or less given offense ah more like defense anywho: since your man of boats tell me what makes a boat fast and safe?
| I think the rudder is supposed to stall at high angle of heel. Something about getting the bow back into the wind and the hull back onto the water. Hope you have your righting lines rigged! Peace love and happiness May the wind at your back not be your own! |
| wouldn't a rudder that was fully functioning as a rudder better steer the boat if your rudder is ( lets guess ) 30-40 percent elevator and 60-70 percent rudder, now if your rudder was 100 percent rudder and 0 percent elevator ? simply = more control if a rudder is 30-40 percent elevator on a one dimensional playing field give or take less than 10 percent of the second lateral dimension that ten percent walks a very fine line of lift and mostly a position of drag in the one dimension of water . as a whole/scale level water is flat ,on top, under or just above . fine line of being under or on top when a constant just above is what you want . I do indeed hope I have enough left over rope to right this thing.
| beach cat | Natsu | Multihulls | 17 | 04-14-2010 05:32 PM |
| 3m Beach Cat | Capn Mud | Multihulls | 0 | 07-20-2009 10:51 PM |
| Folding Beach Cat | jtremolo | Multihulls | 8 | 05-31-2008 10:29 PM |
| Beach cat building | sailinaggie | Boatbuilding | 5 | 03-08-2007 08:53 AM |
| Wooden beach cat | mrthethird | Wooden Boat Building and Restoration | 11 | 09-20-2005 07:56 AM |
