| Turning a planing hull into full displacement Could a steel planing hull be turned into a full displacement hull by welding on a bow bulb? |
| i wouldn't try it planning hulls are meant to be their most stable while on plane, besides most boats of the planing type are too small to benifit from a bulb in anything except a flat calm. Imho you would be better off not trying to do such a conversion. How ever if you still want to go ahead, i'm just saying i wouldn't do it. |
| There are displacement and planing speeds for hulls. The design takes into account the target speed. The bow is only one of the design parameters. However, a bow bulb is not even close to converting a hull designe for planing speeds to be efficient or effective at "displacement speed"
__________________ Gonzo |
| You would also have to address the water flow at the stern. No small task, but it could be done if you don't mind increasing the OAL. |
| Jaja, and what would be the OAL then? lets see it so: you can make a Porsche pull a trailer like a Truck, you can make it going slow like a Truck, but you can not transport a fridge, without destroying what makes it a Porsche. Sell the Porsche, buy a Truck! Or be fine with the given limits, anything else makes you unhappy and wastes your money. Regards Richard |
| Apex; SO you are advising the OP to sell the planing boat and get a proper displacement boat if displacement is his choice. I heartily agree. Although I have never seen a Porsche pulling a trailer, your analogy is sufficient. |
I´ve seen Porsche´s pulling Horses and boats on trailers, does that count? ![]() |
| Turning a planing hull into a full displacement fiftysixer, Yes. Homefront is on the right trail. Change the quarter beam buttock line (QBBL) of the hull. In a sentence, change the shape of the aft part of the hull below the WL so the bottom ramps up from about 1/3 fwd to the transom at approx the static WL. Basically it must be a hard chine boat. Exotic composites and ferro-cement would be difficult but wood, steel or aluminum and fiberglass should present few problems .. mostly just work. For example: a 36' GB w two 120hp engines burning 6gph at 8 knots, if her stern was turned up so the transom was out of the water would go 7.5 knots w two 55hp engines burning 1.5gph. I was once hot to convert an old Chris sedan (34'). Would have been ideal for the mod. A fairly narrow boat w a nearly flat bottom aft. You can choose how "displacement" you want it to be by adjusting the height of the bottom edge of the transom. If you want the above GB to go 8 knots and only burn 3.5 to 4gph leave about half the amount of submerged transom of the original configuration submerged. In quarter beam aft seas the resulting boat will be considerably easier to control directionally. If fiftysixer has plenty of time and not much money this mod could be a good move. The expense in money and time would need to be ballanced w the advantages of the end result. I am only an amateur NA so anything I say needs to be considered an opnion but I believe the above to be true. Easy Rider |
| I think it is worth to bring fiftysixers question into the right context: 1956 steel hull roamer question that makes it much easier to understand the reason. |
| Apex1, Am I to assume a Roamer is too old and rusty to weld? Easy Rider |
I restored ships more than twice that age. But I can see little sense (in fact none), to convert a good functional boat, a sort of oldtimer actually, into a krook. Not capable of what the owner wants in the end. Leaving it as it is, provides the trolling speeds he wants, though not perfect, but it does. And it gives the opportunity to go home fast and comfortable. A conversion as planned (or discussed), may end up in a more fuel economic vessel at trolling speeds, but the speed wil be gone, and it would cost several times the (now wasted) fuel over hundred years of service. I doubt the boat will see much more than another hundred years of service. Let me know if time has proven me wrong, ok? Regards Richard |
| I bought the fiftysixer in August without even seeing it out of the water. My goal is to figure out what type of hull I have to figure out optimal cruising speed for the best economical results. At first I assumed that it was a planing hull. After logging some hours on the water I am not convinced. Before I had to shore her for the year i ran some speed to rpm tests. @ 1200 rpm = 6.26 knots 1500 rpm = 7.65 knots at these speeds the boat felt 'right' kinda gliding through the water with no sense of strain. Then I pushed her to 2800 rpm = 18.25 knots then 3100 rpm and could not break 20 knots and the boat felt very strained and had some vibration. The boat has twin 350 cubic inch crusaders - model 270. Below are some pics I took today when she got pulled. Can someone please help and tell me if I have a porsche or a truck? |
| You have a planing boat with a moderate hull form and according performance. A heavy boat btw. What did the crane gauge say? A Mercedes 220 Diesel! A nice one. You said something like 28 knots full throttle in one of your former posts, I do´nt understand the difference now? Richard |
| What you have is a Chevy. Those boats give you a nice ride at moderate speeds. At the time, their speed was respectable.
| Hull displacement performance versus planing | dallolio | Multihulls | 0 | 08-01-2009 10:33 AM |
| Displacement hull replace planing hull | Fanie | Powerboats | 11 | 01-30-2008 07:51 PM |
| Displacement/Semi/Planing | Hotel Lima | Boat Design | 10 | 09-28-2007 01:41 AM |
| Full Displacement of semi | tdamico | Boat Design | 51 | 02-18-2004 10:42 AM |
| Displacement vs Semidisplacement vs Planing | Fernando | Boat Design | 10 | 12-19-2002 08:04 PM |
