Old 09-04-2010, 06:46 PM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
tunnel slot design?
Ran into designs for tunnel slot speed boats. Having never seen one or read about one i was curious what advantage they might have over mono hull v planning hull speed boats ....
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 09-04-2010, 07:09 PM
Questor Questor is offline
Rep: -25 Posts: 202
What is a tunnel slot speed boat ? Do you have pictures ?
In the Quest for Development and Application of Hybrid Technology we must turn to the Penguin for Inspiration.
Old 09-04-2010, 07:12 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Its like a catamaran but the hulls are much closer. Looks like a mono hull with the bottom middle part removed
Old 09-04-2010, 08:01 PM
Rep: -25 Posts: 202
That's the same hull design as my dollar store, battery powered kitchen sink research vessel.
Old 09-04-2010, 08:04 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Good for your kitchen sink vessel ...
So any 1 know of this design ?
Old 09-05-2010, 06:47 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Does any one know more details ?
Old 09-05-2010, 10:02 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
It reminds me a little of the split-vee hulls from 25-30 years ago. (e.g. the arnow 27 split vee or the arnow 39 "blue thunder" sold to customs) - but even less tunnel. Around that time a couple builders were doing something like this -- e.g. from the 1981 wellcraft brochure (attached) the cougar cat (I don't think there were many of these sold here)
tunnel slot design?-1981-wellcraft-cougar-cat-1.jpg  tunnel slot design?-1981-cougar-cat-3.jpg  tunnel slot design?-1981-cougar-cat-4.jpg
tunnel slot design?-1981-wellcraft-cougar-cat-2.jpg  tunnel slot design?-1981-wellcraft-cougar-cat-3.jpg
Old 09-05-2010, 10:05 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Hmmm .... i havent seen any tunnel designs recently, the pics i found are from Glen-L fiberglass design. Looks like old designs too.
Old 09-05-2010, 10:36 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
a small slot, like smal strakes only gives small lift, but there is much more to it, small hull's (LBx2) etc
more reading on http://en.wikipedia.org/wiki/Tunnel_hull and http://en.wikipedia.org/wiki/Offshore_powerboat_racing
and http://www.aeromarineresearch.com/pu...vDec_2008.html and on this forum
and nice article you have saved there Jeff, nice pics and good read
Old 09-05-2010, 10:42 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Thx ! I still do not see if it has any major advantage for speed boats (not racing boats).
For example do they provide addition stability, greater comfort or speed only?
Old 09-05-2010, 11:58 AM
yipster's Avatar
and how about efficiency, yes there's much more to know about them
http://www.boatdesign.net/articles/t...sign/index.htm
http://www.boatdesign.net/articles/d...rust/index.htm
http://www.boatdesign.net/articles/d...nces/index.htm
if you only like older classic shiny heavy wooden speedboats than dont read
Old 09-05-2010, 12:34 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
If it floats, has an engine then i love it However i am more interested in the every day main stream application rather than specialized fields like racing, or speed records etc...
Very interesting read !! I thought only hydrofoil utilized air lift principles.
The picture i posted does not seem like a tunnel design, there is simply not enough space to create the lift effect and the 2 hulls are very close to each other.
It looks like a squeezed catamaran design. It does seem to my untrained eyes that kind of configuration will have better stability and less tendency to roll. It would also seem that the amount of power needed for a certain speed could be lower than a normal mono hull.
However it might have less weight carrying capacity.
(just my ranting)
Thx for ur links yipster keepem coming please
Old 09-08-2010, 06:48 PM
yipster's Avatar
your right, getting into and over hullspeed you mean
Old 09-08-2010, 07:33 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
So if i had a choice between 2 almost identical speed boats for cruising and water sports, why would i choose a tunnel design over a normal hull?
That's what im trying to figure out !
Old 09-09-2010, 06:23 AM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
I just love the styling of the 70s. I find this boat's lines so simple, yet very appealing.
Aerodynamics of the slot chabrenas Sailboats 18 02-08-2009 05:48 PM
Design help, making a tunnel clamsalot Powerboats 22 03-03-2008 10:11 PM
Pocket tunnel design HELP bahamabay Boat Design 29 02-14-2008 05:58 AM
tab a - slot b construction method Tinkerer Boatbuilding 4 07-26-2004 10:00 PM
Slot effect? brieninidaho Sailboats 1 05-09-2004 11:17 AM
