| Tunnel Prop Question I am going to repower an old 27ft Uniflite with a cummins and about a 20dia prop. I do not want to loose all the draft with a propeller sticking down. Can a cut a "tunnel" in the bottom of the transom and tuck it under without loosing efficiency? I do not have much engine compartment this tucking up would also help with the angle off the back of transmission. How would I design this? Thanks |
| big-boss, you can download a very interesting paper on propeller tunnel design from Donald L. Blount and Assoc., Inc.. Maybe this is of some help...
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| prop tunnel hull jon boat? | Doober | Boat Design | 6 | 01-24-2008 10:22 AM |
| Is a tunnel for the prop better than regular bottom? or will it restrict flow? | clctrader | Boat Design | 2 | 12-10-2007 12:41 PM |
| prop tunnel modification | Captain Grog | Boat Design | 2 | 09-28-2006 02:46 PM |
| Small 60 - 90 degree tunnel to get bigger prop viable ? | globaldude | Sailboats | 1 | 08-15-2006 02:16 PM |
| Prop size question | jerryniff | Sailboats | 4 | 01-11-2006 10:26 AM |
