Old 08-09-2005, 11:41 AM
simonB simonB is offline
Rep: 10 Posts: 8
Tuning the pitch of Waterjets
Times goes by from when you define a projet and order the WJ and then when finaly you do the sea tryals... a lot of things could change so a different pitch of the WJ impellers is required to reach the best performance.
As far as you know, did someone produce or develop variable pitch waterjets?
SimonB
I like wj, mostly when they're couplet with gasturbines
Old 08-09-2005, 11:38 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Variable-pitch water jet? Seeing as good impellers are already horrendously complicated compound shapes cast as single units, making a variable-pitch one that works would be pretty tricky. Maybe put a CVT in front of it instead?
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
Twin Propeller pitch question Boataholic Powerboats 1 01-23-2005 09:41 AM
prop pitch bmeasurements spike Props 1 12-31-2004 11:03 AM
Design of variable pitch propellers? anybody got a clue? Freddy Lemieux Boat Design 13 08-02-2004 06:01 AM
Drive Ratio and Prop Pitch rayjay Powerboats 3 04-22-2004 03:07 PM
