| Tug Weight estimation Could any one tell me how to estimate the light weight of a towing and oil recovery tug (principle dimension are known) I know a several methods based on a basis or sister ships, but I have a shortage in available data so I can’t use these methods I need fast formula (not accurate but almost near) I found this formula: Light Weight = 0.2 (L.B.D) tons Is this formula true? |
| If in meters, more like 0.5*L*B*T = tonnes Where L = LWL, B=max beam waterline, and T = midships keel draft. How you measure D (depth of hold) or T (draft) is the key for these "rule of thumb" "calculations". |
| Your formula can be used to determine weight of an existing tug (has a known draft) This equation based on Cb and Cp that they vary from (4.5 – 5.5) for tugs What I need is to estimate the light weight in first design stage, then I can make a prediction of draft on witch the coming steps of design will depend on |
| You have it backwards, in the classic design spirial... 1) select L, B, and T first from shape/tonnage laws/mission considerations 2) draw the lines and curves of form 3) do the structural weight/strength 4) add the propulsion, outfit, and stores/cargo 5) check against the L, B, and T, and around the design spirial again. If what you want is a quick and dirty structural weight then here is a way to get close. shell weight = surface area of the hull * plating weight deck weight = surface area of the decks * plating weight plating weight = shell weight +deck weight structure weight = 50-70% of plating weight light ship weight = plating weight + structure weight+ machinery weight + 7% of the total other weights for paint and welds/fastenings. |
| According to my notes on tugs, a first approach to displacement in light ship condition (WR), when in the first stages of design, is: 0.24*L*B*D < WR < 0.29*L*B*D (Metric units) (L =Lpp) For ice-going heavy reinforced tugs, superior limit may go up to 0.34*L*B*H
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| A second way of estimating WR, is: WR = k1*L*B*D + k2*PB (being PB the propulsive power in kW) k1 varies between 0.18 and 0.26 k2 varies between 0.08 and 0.1
| 3D Max tug | Bassoom | Software | 2 | 06-11-2005 08:38 AM |
| Average Human Weight, Safe Excess Weight, &c. | Free Pirate | Boat Design | 12 | 03-14-2005 01:40 AM |
| Tug Trouble | jfblouin | Open Discussion: All Things Boats & Boating | 1 | 01-27-2005 10:42 PM |
| Resistance Estimation | redcoopers | Software | 4 | 01-01-2004 09:08 AM |
| Powering estimation 1 days process...USD 200 | fadly2000 | Services & Employment | 0 | 07-02-2001 12:45 AM |
