Old 11-20-2011, 04:37 PM
ONEOFAKIND ONEOFAKIND is offline
Rep: 10 Posts: 4
Trim Tabs information needed
I am new to this forum and not sure the best place to ask this question
I have a 18' flats boat w/tabs 9x12 on it and not getting the low speed lift needed to jump up in skinny water. I found a set of 9x18 and want to know if this will help.
Thanks for any help you can provide.
Old 11-20-2011, 06:08 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Yes,with tabs more is better. If Bennett all you need to change is the tab and hinge, everything else stays same same as long as the ram stays centered on the larger tab. Steve
Old 11-20-2011, 07:11 PM
Rep: 10 Posts: 4
Thanks
will it matter that almost the entire lower part of the transom will be tab?
They will not be in the way of the motor but it will take up everything else.
Old 11-21-2011, 03:03 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
As such that shouldn't matter. The problem with adding more tab is that you add unnecessary drag when you are on the plane. That is your compromise.
If the boat still requires some trim tab at high speed i would say increasing the tab size should't affect high end performance, but improve low speed lift more efficiently.
Old 11-21-2011, 06:00 AM
tabman tabman is offline
Rep: 24 Posts: 20
Actually, larger Trim Tabs do not necessarily add more drag. The larger Trim Tab will need to be deflected to less of an angle to generate the same amount of lift as a smaller one. So it will have a better lift to drag ratio.
Also properly installed Trim Tabs angle up above the hull bottom when fully retracted. This raises them above the waterflow when on plane. When the boat is running at high speed with the Trim Tabs all the way up there should really be no additional drag.
I would add that you will want to keep the inboard edge of the Trim Tab at least 8" from the centerline of the outboard's lower-unit to prevent disturbing the waterflow to the prop.
Tom McGow
Bennett Marine
Old 11-21-2011, 10:31 PM
beachcraft beachcraft is offline
Rep: 15 Posts: 40
Are you going with wide short tabs or narrow long tabs?
I had a small aluminum skiff which required me to lean way forward to plane. This was already with the gas moved to the bow. I fitted a set of 18" long tabs which were really big for this size skiff. But they made it plane out with no trouble very quick. And they were clear of the water when running at speed mounted about 3/4" higher than the bottom.
Old 11-22-2011, 06:12 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
Does anyone here think that tabs will reduce the draft needed to launch? What is the technique for non jackplate boats.
Old 11-22-2011, 06:32 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Trim tabs
18 x 9 against 12 x 9 The 18 is running across the boat each side and the 9 is sticking out the back ?? How do tab actually work ! All they do is difflect the flow of water down and there by lifting the back of the boat at the same time . the fast you go the more lift and flat out you should only need a very small amount of trim as you slow down you need to increase they can also be used to trim the boat while under way . The extra drag thing is not even worth thinking about unless you are doing 100mph plus !!
Making beautiful boats is a passion never a chore !
Old 11-22-2011, 06:35 PM
Rep: 10 Posts: 4
the tabs are 18" wide and 9" deep.
I will have plenty of room for the motor.
I do have a jack plate and that is why i need to push the stern up at lower speeds so that i can let it down for the initial launch.
Does this sound right????
Old 11-22-2011, 06:47 PM
old one !
You need to try a few options Yes the prop needs more bite to get on the plane so possibly need to be lower and with the trim tabs you could be on the plane very quickly so maybe the motor need to go down just a small amount you have to do a little exsperimenting . Every situation is differant its a individual thing what works for you may not work for everyone . Seat time and push a few buttons !!do it scientificly not just randomly
Old 11-22-2011, 07:18 PM
Rep: 10 Posts: 4
that is what i was planing on doing after i made sure that the tabs would help not hurt.
With the jack-plate all the way up i can get to about 7 MPH and after that the boat drops and starts sucking mud. I am hoping that the larger tabs will allow me to get enough speed to help lift the stern so i can hole shot to plane.
A little more info for you to see what i am trying to get accomplished is that this boat is 18' long with the big block Suzuki 150 on it. it is on plane very fast in 3' of water but i want to get up in skinnier water so i don't have to idle out for 20 MIN to relocate.
If you or anyone else has any ideas please let me know
Thanks
Old 11-22-2011, 07:58 PM
Rep: 205 Posts: 442
The following technique involves some aquired skill. With the boat healed by passenger weight into the turn slowly start making circles. This gets the prop off the bottom a little and starts making a little wake. Slowly increase the speed until you "feel" the time is right. The trick is to throttle up and straighten up at just the right time to use the wake and the speed you've developed to help you jump up on plane.
This is a trick I learned in the Keys (see my screen name.) It does involves some practice so maybe try it in deeper water first and maybe transition to really soft bottom shallower water before getting yourself 30 minutes on plane into a flat.
Good luck, Steve
Old 11-23-2011, 12:58 AM
kapnD kapnD is offline
Rep: 19 Posts: 143
OK, Im in for $.02.
Post #11 explains the percieved problem: 150hp big block Suzuki!!!
Why so much power on so little boat?
I know there are tons of flats boats out there set up this way, but I just dont see the need for so much hp and the resulting weight and fuel.
Most true flats boats only require 50 or less hp to run at a fair clip, and are really easy to pole around without the stern practically underwater, where inches matter in your ability to fish skinny water, as well as being able to easily plane up and get out of there.
Old 11-24-2011, 08:03 AM
philSweet's Avatar
Rep: 658 Posts: 621
Exactly like Keys says. Sans jackplate, the motor had to be kicked up some. You could spin, trim and go with a bit of practice. I haven't seen it with a jackplate and big motor though. I think you need light weight and little transom immersion to start to plane sideways at low speed with a bit of boat heel. Turning the motor also reduces the effect of the prop sucking all the water out from under the boat.
QL trim tabs or classic trim tabs?? pikac Hydrodynamics and Aerodynamics 4 08-02-2011 04:49 PM
Trim tabs 640 blazer Powerboats 4 03-18-2010 04:25 AM
Trim tab options between bennett and kplanes? Lenco trim tabs? Red Tide Powerboats 5 11-19-2009 06:59 AM
Trim tabs John Perry. Marketplace 1 09-17-2005 08:11 PM
Trim Tabs stevel Powerboats 0 09-20-2004 03:13 PM
