Old 05-29-2006, 12:09 AM
James Francis James Francis is offline
Rep: 10 Posts: 21
transom support
I have a 22 inboard and I am in the process of installing a 9.9 auxillary engine(90 lbs) on a new garelick outboard 4 stroke bracket. The bracket is very beefy but I was hoping for some input on the ability of the transom to handle the stress. The boat is a 79 chris craft CC so it is well built, The transom has a convex shape and at a slight angle and is 3/8 - 1/2 solid glass. Since the boat has much needed trim tabs, the bracket is going to have to be mounted near the center which has a little more flex than I thought it would. I have mounted the bracket with a 1/2 marine ply backing plate.
Any thoughts as to whether the transom should be able to handle the load of a 9.9 in any type of condition?
Thanks,
James
floor support brackets? drs3317 Fiberglass and Composite Boat Building 3 07-07-2005 11:53 AM
Do I need the mast support? Gregor_L Sailboats 4 05-11-2005 05:38 PM
HullCAO - any experiences with support? yago Software 3 03-04-2005 02:50 PM
Looking for suggestions for hull support. murphy Fiberglass and Composite Boat Building 2 07-25-2004 06:39 PM
stringers and support strandedturtle Materials 0 07-02-2004 12:02 AM
