Old 09-19-2010, 07:19 AM
Rep: 3125 Posts: 9,398
Use double planked 3/8" or 1/2". Better yet would be a 1/2" plywood core with a 1/4" planked veneer on each side. The plywood core will stabilize the solid wood planking, so it can't leak. Also you can do this without fasteners, so no bungs or fastener head filler to fool with, which is a good thing.
Old 09-19-2010, 11:12 AM
jimbo2010 jimbo2010 is offline
Rep: 42 Posts: 32
Thanks,
How about adding a lite 4oz fiberglass cloth (or mat) between the the ply and planked veneer, clamp until cured.
I don't think a 5 hp will flex that.
Old 09-19-2010, 03:41 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
The strip method will work best if the middle layer is 1/4" plywood in which case the strips can be wider than typical bead and cove (which you don't need at all if you use a 1/4" ply core).
1/4" x 2 1/2"-3 1/2" would be better looking and less work and yet won't be wide enough to create an expansion differential with the more stable plywood layer.
A curved transom is inherently more stiff than a flat one and doubly attractive, so consider that possability with a 3-layer transom. As described, with a light glass layer inside and out, you'll get your 7/8".
Just noticed PAR's comment (after initial posting) to use 1/2" ply, which would be fine for a flat transom, which is likely what you'll be building anyway.
Old 09-19-2010, 04:45 PM
Rep: 42 Posts: 32
Alan, tks
Since I'm exploring all possible scenarios how do you build a curve into it?
Just build a say a 2" curved form and bend each layer over it?
Old 09-19-2010, 06:23 PM
I usually employ a curved transom, even on straight transom boats. In this case I'd use two internal 1/4" plywood layers, glued to the curve, then veneer over it on both sides with 1/4" solid stock.
If you do use a curved transom, you'll want knees in the upper corners to transfer loads to the inwale. Bend in the plywood rough to get an idea of the curve you want. The best looking transom curve will actually be a conical, not a cylindrical shape. The last one I did on a boat that size had about 3" at the top and 2" at the bottom. It could have been more, but I was going for subtle look.
Old 09-19-2010, 06:30 PM
Rep: 42 Posts: 32
I understand, something like this
I think that was 2 1/2 to zero, but that's the idea, correct?
Old 09-19-2010, 06:59 PM
No, 4 ounce 'glass between the layers will not control much. Epoxy two layers of 1/4" ply together at the curve you want, then veneer it. I'd do it right on the boat.
Old 09-20-2010, 12:31 PM
Rep: 42 Posts: 32
Hi, spoke to tech support at West they agree no cloth just bond with resin.
By the way not sure I mentioned the transom is 30"W X 18" H
Old 09-20-2010, 03:10 PM
Next time, mention me to tech support over at West and see how they react . . . (my luck you'll get the new kid)
Thicken the resin with silica and milled fibers or wood flour (not saw dust). This will improve the bond and compensate for surface irregularities.
  #25
Old 09-20-2010, 03:23 PM
Rep: 42 Posts: 32
Thanks for all your time on this issue, pics will follow.
Maximum Transom and deadrise angle? jimianbu Boat Design 9 08-24-2010 08:20 AM
military bidge boat the transom has no angle what is the best way to attach outboard? o2bfishn Metal Boat Building 3 06-18-2008 10:26 AM
how to design the transom angle with suzuki 300hp nemo4653 Outboards 1 08-22-2007 07:30 AM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 02:14 PM
What is transom angle? chase687 Boat Design 4 06-29-2005 01:21 PM
