| transmission I just purchased a 1985 33 egg harbor. looking to do a complete remodel. I will be pulling out the 454 engines for a complete rebuild. Any advise on the easiest way to get them out from the engine compartment. Also has any one rebuild the transmission, and what ratio are they? can i change the ratio on them to gain some speed? |
| Usually you employ a boom or gantry to hoist the engines out of the boat's belly. A tree branch with a come-a-long can work in a pinch if the boat is on a trailer, though this isn't the easiest method. It very likely the trans will have an ID plate with the reduction ratio stamped on it. A good cleaning will usually reveal this. If not, you'll need a serial number to match up with the manufacture. You can always turn the input shaft and count the revolutions on the output shaft for a reasonably accurate idea of it's reduction. |
| Automobile Transmission, why not? | Ken Gasch | DIY Marinizing | 121 | 01-26-2012 06:24 AM |
| Need Hurth transmission | Psuedomonas | Marketplace | 0 | 08-24-2005 01:48 PM |
| diesel transmission? | ron17571 | Propulsion | 24 | 03-04-2005 10:29 PM |
| Hurth Transmission Noises? | E4ODnut | Propulsion | 4 | 11-29-2004 07:57 PM |
| transmission question | green guy | Powerboats | 2 | 05-22-2002 11:20 AM |
