Old 01-16-2011, 10:54 AM
ClayKorn ClayKorn is offline
Rep: 10 Posts: 4
Trailerable Trawler / Troller for ICW Great Loop
Hello,
I've been reading this forum for some time now and finally decided to post a topic. I realize that this topic was discussed in "economical coastal cruiser". But the thread soon deteriorated into a discussion on the difference between compromise and optimization. Once the thread got back on track, the discussion turned to another boat than was first described.
I’m interested in a trailerable trawler / troller to build in order to cruise the ICW Great Loop. Listed below are the features / requirements I’m looking for in current order of importance.
1) Hull can be built in a 3 car garage ~ 20 x 30. ( I realize the superstructure will have to be built outside due to ceiling height).
2) Easily trailerable: 8.5' beam max, total trailer weight 8000 # max
3) economical to operate (displacement hull) ~25 hp.
4) Reasonable Accommodations:
a) double berth
b) head with shower or separate shower
c) standing headroom in galley
d) easy access to the fore deck
e) enclosed pilot house
I’m open to either inboard or outboard power. The stern drives that I have seen seem to be outside of the power requirements of “economical to operate”.
In my search for plans, I like the Coastal Cruiser and Hercules at Glen-L. They seem to meet most of my requirements. However, I wanted to see what else was out there before I purchased any plans.
https://www.boatdesigns.com/25-Coast.../products/802/
https://www.boatdesigns.com/24-Hercu.../products/395/
Thanks for any responses
Clay
Old 01-16-2011, 01:18 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
Trailerable Trawler / Troller for ICW Great Loop-champlain_profile.jpg
Old 01-16-2011, 01:20 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Google Champlain by Phil Bolger.......
Trailerable Trawler / Troller for ICW Great Loop-champlain_arrangement.jpg
Old 01-16-2011, 01:26 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Windermere is the larger version.......
Trailerable Trawler / Troller for ICW Great Loop-windermere_arrangement.jpg
Old 01-16-2011, 05:02 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Trailer Trawler 28 from Chesapeake Marine Designs
www.cmdboats.com
Old 01-16-2011, 05:10 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Sam Devlin has some interesting designs. http://www.devlinboat.com/
His powerboat designs are at: http://store.devlinboat.com/powerboa...wlerplans.aspx
He makes a good argument for outboard power for larger trailerable boats with efficient hulls given the efficiency of today's 4-stroke outboards including considerably lower intial cost than diesel inboard, more room in the boat, and easier to install. It can take many, many hours underway to make up the difference in initial cost, especially after the prop, shaft, bearing, etc are included for the inboard.
Old 01-16-2011, 09:35 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Personally, I think this size is too small to have a separate pilothouse. The spaces are small enough withour dividing them up even further.
The advantage of a separate pilothouse (one that is truly separate) is that the helmsman can still operate at night whilst the rest of the crew can have the lights on elsewhere in the vessel. But the reality is that this would be very seldom - if ever - done on such a small craft with just 2 people onboard.
I also think that connection to the aft cocpkit is better on a single-space boat. Again - you don't have a great deal of space to play with, so anything that you can do to make it 'feel' bigger, the better.
It's a rare day that Tad doesn't haven't anything suitable for just about any wish list....
Also have you checked out Tom Lathrop's Blue Jacket series? The larger 28' boat might be suitable
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 01-16-2011, 10:39 PM
cthippo's Avatar
Rep: 452 Posts: 725
I ascribe to the theory that an important factor in designing the interior of a boat is the ability of the people on board to physically separate themselves from each other in order to prevent insanity and violence.
Old 01-17-2011, 07:53 AM
Rep: 10 Posts: 4
Great Replies!
Thanks everyone for replying.
Tad, the Mark V 28 looks very appealing to me. I plan on looking into this design further.
cthippo, I saw the Trailer Trawler 28 in my search. But, I made the assumption that the plans were not available because there wasn't a link on the site to puchase them and there was a production boat being built from the plans.
DCockey, I do like Devlin's plans. However, most of the plans that had the accomidatons that I would like were over the 8.5' max beam. But, I'll have to explore his site some more. I did read some of the discussion on the economical use of and outboard rather than an inboard and am leaning toward this. A question that sill remais for is the ability for the outboard motor the keep up with the electrical load requirements or if a generator would be needed?
Willallison, your comments make sense. I may have mis-stated my requiremtns. I was really looking for a sheltered helm station more that an totally enclosed pilot house.
Thanks again for the great responses. I am interested in learning more about how an outboard is set up to keep up with the electrical loads. I do like the idea of being able to eliminate the below water line thru hull fitting too with using an outboard. Also, are there concerns when using an outboard for extended times (months) without being able to flush salt water out of it's raw water cooling?
Clay
Old 01-17-2011, 10:18 AM
BrianPearson BrianPearson is offline
Rep: 10 Posts: 10
The Mundoo cruisers from Duckflat look ideal for your needs. I particularly like the idea of the solar electric.
http://www.duckflatwoodenboats.com/mainpages/mundoo.php
Beam is 7'8"
and this one just launched in Canada
Brian
Old 01-17-2011, 10:55 AM
Rep: 10 Posts: 4
Brian, the Mundoo Cruiser is a good looking boat. However, I would be concerned about the pounding of the flat bottom in any chop on the more open bays along the way.
Clay
Old 01-17-2011, 11:29 AM
Rep: 10 Posts: 10
that's fair enough, I thought a tad more seaworthy might be needed.
the bottom is a Bolger type, how do users find such a shape behaves in waves
Selway Fisher have a large range of plans
http://www.selway-fisher.com/Mc2130.htm
Brian
Old 01-18-2011, 02:46 AM
cthippo's Avatar
Rep: 452 Posts: 725
Might just be a glitch in the site. You can contact Karl directly at kstamba103 {at} aol.com
Old 01-18-2011, 07:45 PM
Rep: 10 Posts: 4
Received an email back today and Karl stated "No plans are available while North Pacific Yachts is building them, sorry." if anyone was interested.
Clay
Old 01-18-2011, 09:41 PM
cthippo's Avatar
Rep: 452 Posts: 725
OK, good to know.
Troller Yachts vs Trawler Yachts Greenseas2 Boat Design 163 01-18-2012 11:48 PM
Large capacity small boat for ICW Wavewacker Boat Design 10 09-04-2010 11:24 AM
Boat for cruising the Great Loop fred breyer Boat Design 7 02-07-2010 01:12 PM
Great sail, great gale, a little carnage and lessons learned CharlieCobra Open Discussion: All Things Boats & Boating 9 11-20-2007 12:49 PM
Potentially Trailerable Trawler List Portager Open Discussion: All Things Boats & Boating 1 02-03-2003 01:44 AM
