Old 02-16-2012, 01:49 PM
narnold narnold is offline
Trailer usage for launching
Hi. I am a Design Engineer at the University of Nottingham, currently undertaking my final masters project with the topic of watersports transportation and security. My main focus is on how to improve trailers for boat users. Please complete my short online questionannire (use link below) or leave any comments if you wish to help. Any answers are anonymous and much appreciated. Thank you
http://www.surveymonkey.com/s/VYTHVZD
Old 02-16-2012, 02:18 PM
Rep: 990 Posts: 3,764
Jeez... dont have the patience for the questionnaire.
One problem with boat trailers is storage once the boat is in the water. Why not reduce a trailers footprint when not in use ?
Many boat owners damage there boats during storage because they didnt raise the tongue high enough to allow any water which leaked into the boat to drain out of the transom plug. Why not build a bubble level into the tongue ?
Tires are damaged when the boat sits on them during storage Why not make it easy for a boater to jack up and block the trailer ?
Each year boaters spend millions repairing trailer lights . Hmmmmmm...............................
Old 02-16-2012, 08:51 PM
Willallison's Avatar
Rep: 2366 Posts: 3,560
The emergence of good LED trailer lights that are completely sealed all the way up to the front end of the trailer has done away with most of the lighting issues.
But the bloke who comes up with afoolproof bearing and brake systems that don't fall apart the after the 1st time it's dipped in salt water.... well.... he'll be my hero.
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 02-16-2012, 10:17 PM
tom28571 tom28571 is offline
Rep: 1581 Posts: 1,866
So right will. I recently tore off and disposed of the second set of brakes. Neither worked satisfactorily for more than one year. No brakes now but, at least the wheels don't lock up. Installing LED light system and have to seal the connections at the side lights. One thing I would be willing to pay for is gold plated trailer electric plugs. A foolproof and waterproof connector would be nice. How about rust proof springs? How about a built in walkway on trailers for large boats?
Tom Lathrop
Old 02-16-2012, 10:24 PM
Stumble Stumble is offline
Rep: 670 Posts: 1,308
The biggest improvement I could see would be some way to minimize the amount of space the trailer takes up when the boat is on it. I know a lot of people paying $100/month just to store the trailer plus slip rental.
Some way to lean it back over the aft end... Maybe have it collapse down from there.
Greg Rubin
Salesman - Allied Titanium
http://www.alliedtitanium.com/produc...dc_Results.php
Old 02-16-2012, 10:26 PM
If you're prepared to pay for them, there's a crowd in Oz that make bronze hubs, brakes etc. They are the best we've found...
www.titanbrakes.com.au
Our LED's came with quite long wiring. We ran all of them up to a (sealed) junction box on top of the winch post, then a nother set down to the pin connector. Never had a problem since
Will
www.imaginocean.net
Old 02-17-2012, 03:33 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1653 Posts: 2,675
Here in Europe most trailers are built by idiots. Open ended chassis tubes and axles, unprotected brake parts and hub seals that cannot even keep the dust out. Instead of hydraulics simple Bowden cables are used; the invention of stainless steel hasn't reached this part of the industry yet. Because the light bar must be removable, there are unsealed wiring sockets bolted to the chassis behind the wheels. To fool the customer there is a cap covering the socket when the plug is pulled, but the backside is exposed to seawater.
With the trailer connected to the vehicle you can see a trail of foam emerging from the submerged sockets at the rear when the driver steps on the brake.
cogito, ergo sum (Descartes' credo)
Old 02-17-2012, 11:36 AM
CDK,
I think I own that trailer. It's amazing how poorly built they are around the world.
Greg Rubin
Old 02-17-2012, 03:42 PM
hoytedow hoytedow is offline
Rep: 2142 Posts: 4,227
It's planned obsolescence just so they can hit you with the after-market light kits.
http://en.wikipedia.org/wiki/Planned_obsolescence
Hoyt
The TITANIC sank because it had a hole in it(still does). Submarine Tom
You just can't put too much info on your patterns. DGreenwood
Epoxy types and usage steveroo Wooden Boat Building and Restoration 5 03-12-2009 10:17 AM
How much water - usage aboard Fanie Multihulls 39 05-12-2008 10:47 PM
Glass usage in boat building PawelDz Materials 3 04-27-2007 07:49 AM
Glass Usage In Boat Building PawelDz Boat Design 0 03-27-2007 09:16 AM
Usage of microsphere, microballoons and silica miss dynamite Fiberglass and Composite Boat Building 1 05-08-2005 03:57 PM
