Old 11-27-2008, 04:00 PM
woodchuck woodchuck is offline
Rep: 10 Posts: 14
tow boat like hull
I want plans for a small (24' or less) hull designed like a tow boat where the shaft goes straight out through the hull parallel to the deck and the prop is higher than the keel to protect the prop. I would like to mount an outboard on a transom plate solidly and steer with a rudder behind the prop. That should allow for a very small opening in the fantail, deck or what ever it would be called. Like a tow boat the hull would protect the prop from oyster beds and bottoms in general. Any suggestions?
Chuck2
Old 11-27-2008, 06:08 PM
captword captword is offline
Rep: 10 Posts: 79
what is your real goal with this boat? a cabin or all open, where do you operate the boat? have you looked into jet drives? they can be hidden under the fantail
Old 11-27-2008, 06:13 PM
Rep: 10 Posts: 14
I want a cabin. I live near the intracostal in Texas and want to travel it as well as fish several bays where shoal water is frequent. Past experience with jets has not been great and would prefer prop.
Old 11-27-2008, 06:36 PM
Rep: 10 Posts: 79
look at this utube vid , he has done smaller versions too, he did it first on a boat the size you are looking to build and that may be forsale, the boats now over a year old and made it to the bahamas and back
http://www.youtube.com/watch?v=U60rx06Dmtk
Old 11-28-2008, 07:49 AM
Rep: 10 Posts: 14
I think he is on to something there. Great protection for the prop. Out of a retired teachers range but really neat. An outbaord in the tunnel would probably work since I am interested in a displacement hull and not speed. I also don't want to give up space for an inboard.
Thanks for the address.
Chuck2
Old 11-28-2008, 07:03 PM
eponodyne eponodyne is offline
Rep: 166 Posts: 327
You could look at some of the Atkin Seabright hulls, some of them liek Everhope, Little Water and Rescue Minor might just be what you're looking for.
You make Baby Jesus want to drink Scotch out of the cat bowl
Old 11-29-2008, 08:32 AM
Rep: 10 Posts: 14
thanks will do
Boat width - You can tow 'em wide here tom28571 Boat Design 6 09-28-2008 02:27 AM
Cheap Tow Testing Sean Herron Boat Design 16 03-30-2008 06:35 PM
Design project - model tow test Brands01 Powerboats 6 01-10-2007 03:48 PM
Stevens High-Speed Tow Tank Re-Commissioning and Technical Symposium CDBarry Press Releases 2 10-13-2006 12:35 AM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 02:18 PM
