Also, bicycle chains, sprockets, and other hardware are widely available and inexpensive, and a working unit can be assembled with minimal machining or other custom work. I do wonder how a twisted chain compares efficiency wise to a 90 deg gearbox though. I also wonder how close that model airplane propeller comes to a purpose-built one (which would be many times more expensive). |
Geno |
I picked mine up surplus for $50, it weighs about 3.5 lbs. |
| On the drive unit: It was helpful getting feedback on the suppliers of angle drives. My latest thoughts are not to use an angle drive for the following reasons: For a suitable three way drive, one supplier quoted US$350. This seems a bit expensive. I would expect a bevel drive to be less efficient than a twisted chain drive. I would like to have a 4:1 amplification. The most I have seen with bevel drives is 2:1 My latest preference is the twisted chain drive unit you can buy from China for around $250: http://www.msu.edu/~pengchun/ I would be interested in critical comments about my thoughts and any experience in using this unit. On CAD: I have been able to use Rhino to derive the shape to cut the plywood. It uses some of the techniques previously described but with 2 additional steps. It would not unroll for me without the additional steps. 1. Slice the hull into segments using an athwartship plane. 2. Define the edges of each segment. (additional step 1) 3. Contruct a surface from the edges. (additional step 2) 4. Unroll the new surface. 5. Layout all the surfaces aligning the corners. For most of the hull I was able to take slices 500mm apart. However near the bow and stern, it would not unroll untill I made it finer slices. The smallest slice was 20mm. Brian |
| the angle drives can be had much cheaper, and you don't use the angle drive for your gearing. Get a 1:1 angle drive, and use the sprockets (chain ring in the crank and freewheel on the angle drive axel) for any ratio you like, including 4:1 you mention. Twisted chain is a some what problematic solution from everything I have read. They often have derailing issues etc...some of the best boats I have seen, including long distance endurance type boats use bevel gear drives. as for paying $250 plus shipping for that twisted chain unit...those are very easy to make for $50...plans can be found with materials list and instructions many places on the net. Geno |
| Combining Foam and Plywood construction in the Same Hull | CET | Boat Design | 21 | 03-11-2006 12:25 PM |
| plywood vs balsa deck construction? | matalag | Wooden Boat Building and Restoration | 33 | 02-27-2006 11:05 PM |
| Foam/Plywood boat plug construction ?s | cla17 | Boatbuilding | 22 | 05-21-2005 02:44 AM |
| MEGA YACHT DESIGN & CONSTRUCTION | Daniel Fenton | Services & Employment | 0 | 03-21-2005 10:20 PM |
| Foam / Plywood Boat Plug Construction ?s | cla17 | Materials | 2 | 05-18-2003 06:45 PM |
