Old 01-09-2012, 02:25 PM
Rep: 1758 Posts: 1,561
Originally Posted by DCockey View Post
Stokes 2nd order theory includes finite water depth if the finite depth version is used. Ocean Engineering Wave Mechanics, Michael E. McCormick, pp 46-47. "The second-order theory yields reasonably good results when the depth-to-wavelength ratio is greater than 1/10, which is the practical range for most engineering applications." It also predicts limiting wave height. Particle paths / orbits can be calculated and will have a net convections.
"resonably good" is what is at issue here. Yes second order accounts for depth and predicts a maximum, but quicky diverges from truth as the bottom shoals with respect wave length in large seas. For a condition of d/L = 0.1 the Stokes 2nd order errors are 7%, 13%, 24%, 39%, and 50% for H/d of 0.1, 0.2, 0.4, 0.6, and Hmax respectively (see Mechanics of Wave Forces on Offshore Structures by Sarpkaya & Isaacson, Fig 4.5 page 176). Stokes's 5th order gives much better results for waves in shoaling water.
Of course, where you expect to operate really influences which theory you pick, especially in as shallow as 5m with a H1/3 of 0.5m (assuming the 2m mentioned in post #4 is a max, not a H1/3. If it was an h1/3 then we are in surf, not waves). Here in the Pacific Northwest I have a hard time convincing people from the East Coast US that there is always a 1m, 15 sec swell to contend with even in SS 0, and a 2m 23 sec SW pacific storm swell could appear at any time, and they should use an Ochi-Hubble rather than a Bretschneider.
<<shrug>> Pick your expert text, pick your accepted limitations.
Old 01-09-2012, 02:39 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
And then there are the waves in the Great Lakes, which folks from both coasts tend to underestimate. It can be flat but when it blows the waves can be steep and short.
Which wave models are reasonable to use also depends on the use of the results from the wave model.
David Cockey
Experience with hydraulic linear drives simon OnBoard Electronics & Controls 0 06-15-2010 05:19 PM
Wave Form theory Cutta Boat Design 0 01-01-2010 06:02 AM
Least Square Method (linear) - Freeboards and drafts Transom6.3 Education 6 09-24-2009 06:08 AM
Colin Archer's wave line theory Proteus Boat Design 2 09-17-2007 10:50 AM
What is "linear urethane"? ErikG Materials 2 08-16-2002 08:15 AM
