Old 09-08-2003, 01:47 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Tiller, Kitchen rudder
2 images of my concept of a simple tiller operated Kitchen rudder have been posted in my gallery. If your not familiar with it, check out this thread.
Kitchen rudder
I would like to hear your opinions ( throw darts if you want ) and or suggestion for improvements. If I stick with this direction my next step is to refine it for ease of construction. Anyone who wants, is welcome to my Rhino file.
Gary
Here are the images:
http://www.boatdesign.net/gallery/sh...php?photo=1134
http://www.boatdesign.net/gallery/sh...php?photo=1135
Old 09-08-2003, 10:12 PM
Doug Carlson Doug Carlson is offline
Member
Rep: 10 Posts: 113
Gary,
How many degrees do you have to raise the tiller to produce neutral and reverse flow? If its significant you might want to actuate it with a rotary actuator similar to an outboard throttle. The disadvantages would be more mechanical complexity and you would mess up the period appearance that the sculptured tiller gives.
Just some thoughts,
Doug
Old 09-08-2003, 10:27 PM
Senior Dreamer
I have been working on a few different versions. This one is an attempt to reduce it to the bare minimum. But thank you, the twist grip idea is one I haven’t considered. I will check the total travel at the end of the tiller. I’m working on some sequence shots to show how it operates.
Gary
Old 09-08-2003, 10:49 PM
Senior Dreamer
The tiller end travels about 18.5 inches to reach full reverse. Which is a lot but not that bad.
Gary
Old 09-09-2003, 07:16 AM
Paul Browne Paul Browne is offline
Registered
Rep: 10 Posts: 31
Kitchen Rudder
Gary,
It might be wise to be mindful of the torque required to move and hold the rudder blades in various positions. The original rudders used a worm, which could have exerted a lot of torque. It wouldn't have required any effort on the helmsman's part to hold it in position either. Unfortunately, it's hard to see how you'd get these numbers without a prototype.
Paul Browne
www.geocities.com/geezerboat
Kitchen rudder duluthboats Boat Design 169 11-24-2011 05:42 AM
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Rudder Design and Broaching joebobb Boat Design 0 02-25-2005 10:43 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 04:36 PM
