Old 06-03-2005, 01:24 PM
Jasen Jasen is offline
Rep: 10 Posts: 7
Thrust tunnel
I've searched and searched but with little luck. The little bit of info I have found is really scientific and about useless to me. I'm trying to find some information on thrust tunnels.
This may sound goofy, maybe it is, maybe it's a waste of time, but I'm planning on building a peddel power boat and wanted to fit a thrust tunnel to the drive unit. The drive unit is actualy like a drive unit off an outboard motor and will also be the rudder.
I'm just not sure about placement in relation to the prop. and length of tunnel, prop. clearance, etc.
Thanx,
Jasen
Old 06-03-2005, 09:08 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
Perhaps a Kort nozzle is what you are after,they are fitted to outboards as well as large craft.They are used for saftey on small boats.
tomkane
Old 06-03-2005, 10:23 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
A few of the lake freighters around here have Kort nozzles; they boost the efficiency of a large prop considerably but these boats have props maybe 240" dia. On outboards they're more to keep prop and solid stuff (logs, people) apart.
Generally, such gadgets are fitted as close to the prop as possible without letting anything touch. They usually completely enclose the prop when viewed form the side. Other than that, you might find some books or drawings but it's mostly trial and adjustment. Given the patience to work the math I would think you could get a decent approximation... but for your pedal boat, I think you'd be easier going with a plain large-diameter, low-pitch prop.
Old 06-04-2005, 01:10 PM
Rep: 10 Posts: 7
I helped install one on a tug many years ago and just thought it might work on a small prop. I can see your point Marshmat.
Just trying to squeeze every oz. of thrust out of each crank of the peddel.
Sounds like it might be more work/math/experimentation then it's worth.
Thanx,
Jasen
Old 06-04-2005, 05:15 PM
tom kane's Avatar
Rep: 265 Posts: 865
Thrust tunnel
Fitting a kort nozzle can give the advantage of a larger prop with out the extra weight of a larger prop and shaft etc.,
tomkane
Old 06-04-2005, 10:40 PM
marshmat's Avatar
That's one of the cleanest outboard-engine nozzles I've seen, Tom (a lot of the ones I've seen look rather crudely built).... just curious, how did it perform compared to the plain outboard?
For a displacement hull like a pedalboat it could be beneficial, perhaps someone here has experience with these things (?). I'd think that on plane, though, you'd want an unobstructed flow to the prop, so perhaps it's a low-speed thing?
Old 06-05-2005, 12:54 AM
Rep: 10 Posts: 7
Tom, Thats exactly what I was looking for. Guess I used the wrong terminology.
With the design of my drive unit it really wouldn't be all that hard to experiment with it. Might just give it a try.
Old 06-05-2005, 04:02 AM
tom kane's Avatar
Rep: 265 Posts: 865
The Kort nozzle is a local make here in New Zealand and fitted to a classic (about 18 HP) 1960 Anzani Electric start dual rotation outboard motor,to protect the propeller as replacement would be difficult.It is usually fitted to a light aluminium 12 foot boat and performance change is not really noticeable.No speedo.Any added appendages must effect top speed.Kort nozzles are normally associated to lower speed application.
tomkane
Old 06-05-2005, 02:08 PM
Rep: 10 Posts: 7
(Kort nozzles are normally associated to lower speed application.)
Thats me....LOL
Some ideas yipster Projects & Proposals 81 02-15-2006 01:32 AM
Tunnel Hull Design for 60' oyster dredge Oystersrus Metal Boat Building 3 12-24-2005 01:28 AM
Prop Thrust Calcs / Bow Thrusters jocko_nc Boat Design 0 04-20-2004 07:32 PM
Oyster Dredge Tunnel Design Oystersrus Boat Design 0 02-21-2004 10:27 AM
Help, Thrust Generated By Outboard Guest Boat Design 3 11-12-2003 03:02 AM
