Old 09-26-2006, 10:57 AM
S Hondros's Avatar
S Hondros S Hondros is offline
Carolina Flare
Rep: 10 Posts: 29
Through Hull Scoop Forward?
I am putting a reverse scoop on the forward part of a center console for the discharge of the macerator pump from the forward fish box. My only thought was that it might have to much pressure when slamming for the pump to handle. Any advice would be appreciated.
Thanks
Scott
Old 09-26-2006, 01:20 PM
Rep: 1758 Posts: 1,561
Originally Posted by S Hondros
...putting a reverse scoop....
I.e. opening faces aft?
Old 09-26-2006, 01:28 PM
S Hondros's Avatar
Carolina Flare
Rep: 10 Posts: 29
facing aft?
correct scoop facing aft
Old 09-26-2006, 01:55 PM
As long as the discharge pipe is not directly exposed to the bottom, i.e. the eductor (because that is what it is) completely covers the pipe opening and the only opening in the eductor faces aft, then I would not expect the slamming pressure to enter the pipe due to the shortness of the event.
However, as you may know, if the eductor is in the water at speed the eductor will suck water through the pump, leading to possible cloging. or collaspe of non-supported suction hose.
BTW, how is the weather down east...my father lives over in Newport.
forward rudder hydroplanes moTthediesel Boat Design 7 09-07-2006 11:49 PM
Forward looking underwater radar Lyle Creffield Open Discussion: All Things Boats & Boating 1 07-09-2006 10:16 PM
Forward props Akeswins Props 8 06-10-2005 09:48 PM
Linux, CAD, and the way forward Tim B Software 20 11-25-2004 06:29 AM
Depthmeter facing forward SamAlec Sailboats 7 08-14-2004 11:20 PM
