| think this would work? Hey all, I want to hear some feedback on this idea. (bear in mind JUST AN IDEA) So i was thinking, it would be cool to have a plexi glass, or similar material, window below the waterline to see fish, reef, etc. The hull is fiberglass, and is not cored, so i was thinking of cutting out the section in the hull, possibly 3'x2' leaving a recess in the hull, where the plezi glass can bed in. Possibly bed it with 5200 or resin (bonging strength to plexi glass?) then, seal around the outside and inside seam of the window with fiberglass. I would prob use 1" plexi glass, about the same thickness of the hull. _____ ______ Fiberglass cover over seam, on both sides _____________ |_____________| Plexi Glass ______ ________ ______|_ _|_________ Hull (solid fiberglass Hole cut out with slight overlap Looking forward to hearing some ideas, thoughts and feedback on this idea. |
| Sorry messed up the Image _____ ______ Fiberglass cover over seam, on both sides _____________ |_____________| Plexi Glass ______ ________ ______|_ _|_________ Hull (solid fiberglass Window with slight overlap Looking forward to hearing some ideas, thoughts and feedback on this idea. |
| Do you know if 1" of plexiglass will have distortion ? My 1st thought was 1" plate with 1/8" plex on each side bonded to the plate. 2nd thought was thick auto glass 2 pieces laminated. I would design a garbage can lid cover to go over it and clamp down tight in case of breaking or cracking. Just some quick thoughts for you. I would want to box the opening up 2" where the glass went inside and anchored to a ledger then a top could fit over and clamp down. Also I would recess the class upward--not flush with the bottom. Basically an under water viewing box without the long sides. |
| There are many glass bottomed viewing boats around, no worries, not for high speed passage making but certainly OK for general bottom viewing.
| Would this work? | altura | Boat Design | 13 | 11-09-2007 07:26 PM |
| How do they work? | justinDesign | Boat Design | 0 | 10-10-2007 05:09 PM |
| Will this work? | usa2 | Sailboats | 17 | 12-02-2005 04:35 PM |
| interior design work experience/work wanted | schwing | Services & Employment | 1 | 01-18-2005 11:52 PM |
| Will this work? | gtcway | Fiberglass and Composite Boat Building | 0 | 12-12-2004 08:48 PM |
