Old 02-01-2007, 09:06 AM
RatliffFranklin RatliffFranklin is offline
Rep: 17 Posts: 191
Is there a theoretical upper speed limit to jet drive?
Is there a speed at which water would be entering the intake faster than the pump could expel it? Or is it just determined by available horsepower?
Old 02-01-2007, 11:09 AM
Rep: 1623 Posts: 1,483
For a jet drive to produce thrust, the inlet velocity must always be less than the outlet velocity. There is a real limit caused by cavitation considerations which leads to a ram pressure issues which causes the inlet to jet diameters to vary in strange ways if you want to go faster.
On the other hand there are some really quirky things you can do theoreticaly...such as a suction drive.
Old 02-01-2007, 11:12 AM
Rep: 17 Posts: 191
Suction Drive
So in theory what might a suction drive look like? And what's the underlying principle?
Old 02-01-2007, 11:15 AM
Suction caused by the lower inlet pressure/higher velocity of a centrifugal impeller.
Old 02-01-2007, 11:27 AM
Rep: 17 Posts: 191
Suction Drive
Okay, now I get it.
You're talking about replacing axial impellers with a centrifugal impeller.
http://www.ualberta.ca/~rchladny/ima...t/impeller.jpg
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Jet Drive CMP Marketplace 20 02-28-2006 08:38 AM
No Limit reached limit Dutch Peter Boat Design 16 09-09-2004 08:20 AM
Theoretical Hull Speed - Cat's GordMay Boat Design 5 01-19-2004 10:29 PM
Speed Limit Alert!!! sharkeymarine Open Discussion: All Things Boats & Boating 27 05-08-2003 06:14 AM
