Old 01-19-2004, 11:42 AM
GordMay GordMay is offline
Rep: 10 Posts: 19
Theoretical Hull Speed - Cat's
If the approximate theoretical hull speed of a monohull displacement sailboat can be calculated:
HS = Root LWL x 1.34
What would be the equivilent formula for a Catamaran?
Thanks,
Gord May
Gord@BoatPro.zzn.com
~~_/)_~~
Old 01-19-2004, 01:11 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
drag specified would get you there but havent seen that cat formula yet...
eventho two hulls have more WSA than a single, its not the WSA but the WAVE resistance determining hullspeed. in HS = Root LWL x 1.34 this is not specified. displacement cats use sharp small beams and encouter less wave resistance. a calculation of those variables times two gives a cats hullspeed i would think?
yipster
Old 01-19-2004, 03:32 PM
Unregistered
Water will behave the same wether it's a mono or two monos built as a cat.
You can run a cat at very low power up to hullspeed. But due to the shape of the two hulls it doesn't need a lot of additinal power to exed hullspeed.... A mono with the same design will behave the same..... but you'll not make a fotune selling them....
Old 01-19-2004, 05:44 PM
Rep: 1397 Posts: 7,215
The multiplier, in your case 1.34 depends on many variables. For example, block coeficient, fineness of entry, displacement/length ratio and type of shape. It is not a fixed number for all hulls. There is no difference in calculations between mono and multi hulls.
Old 01-19-2004, 06:05 PM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
"Hull speed" is just a rule of thumb and doesn't mean much for either cats or monohulls. ULDB monohulls and dinghies routinely exceed "hull speed" by a lot.
Old 01-19-2004, 10:29 PM
Jimboat's Avatar
Jimboat Jimboat is offline
Rep: 113 Posts: 189
Catamaran hull speed
If you're speaking about power catamarans....hull speed is a function of many variables. Check out Secrets of Tunnel Boat Design book.
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
