Old 02-14-2008, 08:58 PM
Roly Roly is offline
Rep: 222 Posts: 490
In terms of rig loading to the hull.....
would the outer skin of a composite hull go in tension first or the inner skin? (If the chainplates were attached to the hull) Is this why,generally, the outer skin is heavier than the inner? (Even though the inner skin is spreading the load from the keel to the hull like a giant washer.)
Or is the loading so simultaneous that it doesn't matter?
Most scantlings stipulate heavier outside.
Any input appreciated!
Old 02-15-2008, 05:49 AM
Wolczko Wolczko is offline
Navarc Student
Rep: 10 Posts: 10
Just in case you haven't seen this thread --> Sail Loading on Rig, Rig Loading on Vessel
I'm no professional, but doesn't it seem like it would be the outer skin that would go into tension first? And more so than the inner skin? I imagine that one could think about a transverse section of the hull below the deck-at-edge as a beam in bending (due to the pull of the rig toward the CL), in addition to being in tension, which leads me to think that while the inner skin may not necessarily be in compression, it would be less in tension than the outer skin.
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
mast loading for hull girder strength on a gaff rigged vessel EAP Sailboats 3 10-02-2006 05:35 PM
Hull deflection under rig loads nico Boat Design 0 04-08-2004 12:23 PM
Boat Building terms Willallison Wooden Boat Building and Restoration 7 03-14-2004 12:22 PM
Design terms...what do these mean? helpful boater Boat Design 5 02-23-2004 10:29 AM
