Old 04-20-2012, 09:46 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Wood Butcher
Rep: 2489 Posts: 5,302
TEOTWAWKI Boat
OK, the fishier boxy catamaran is as follows, roughly:
6' wide assembled (it is carried in 5 sections, 2 hulls, 1 mid deck, one engine mounting crossbeam and one forward crossbeam).
Hulls each measure 114 in. (290 cm) long by 15 in. (38 cm) high by 22 in. (55.8 cm) wide.
FRE on 1/4 in. (6mm) plywood stitch and glue construction.
2 engine mounts designed are based on 15" or 20" outboard leg.
Pictures to follow.
"You need to quit over thinking it[the boat] and build the darn thing."
ADAM87
Fracking is good.
Old 04-20-2012, 09:51 AM
hoytedow's Avatar
Wood Butcher
The jig upon which both hulls will be assembled.
Fracking is good.
Old 04-20-2012, 10:03 AM
hoytedow's Avatar
Wood Butcher
General appearance of hulls when assembled is as follows:
Fracking is good.
Old 04-20-2012, 10:07 AM
hoytedow's Avatar
Wood Butcher
It will look similar to this from the front:
Fracking is good.
Old 04-20-2012, 10:11 AM
hoytedow's Avatar
Wood Butcher
Hull walls are vertical and all external hull curves have a 72" radius. Spray rails will be added later.
I will post photos of progress and any modifications after construction begins.
I call it a fishy boxier catamaran.
Name to be determined later.
Fracking is good.
Old 04-20-2012, 10:30 AM
Frosty Frosty is offline
Previous Member
Your post says 114 feet long?--is that a typo.
along the same lines is 20 HP engines a typo.
I know --it was 11.4 meters with 200HP.
Old 04-20-2012, 10:33 AM
hoytedow's Avatar
Wood Butcher
2 hash marks means inches not feet. 20" is length of outboard motor leg. I plan on getting a motor size from 5 hp up to 15 hp.
Fracking is good.
Old 04-20-2012, 10:39 AM
Previous Member
I understood everything fine.
Looks good.
What's your reserve buoyancy or water line?
Old 04-20-2012, 10:45 AM
Previous Member
Your not going to get through this without me having a few goes at you --you know that don't you?
Laughing smiley here+
I know you have to go advanced for smileys .
Old 04-20-2012, 10:52 AM
hoytedow's Avatar
Wood Butcher
Water line at rest estimated be about 4 in. above chine when level. Loaded boat will weigh (guessing now) 700 lbs. I haven't worked out exact weights.
Crew 400 lbs. approx. (less if diet works)
Boat 150 lbs. approx.
Motor 100 lbs. approx.
Gear and consumables 50 lbs. approx.
Fracking is good.
Old 04-20-2012, 10:54 AM
hoytedow's Avatar
Wood Butcher
I don't mind. If it keeps me on the right track I can endure the slings and arrows. : + ) =
Fracking is good.
Old 04-20-2012, 10:57 AM
Previous Member
Let me reword that.
What's your freeboard under load?
Old 04-20-2012, 10:59 AM
hoytedow's Avatar
Wood Butcher
This boat is similar to the first one I built and it performed very well for me 41 years ago. That boat was 12 inches (3 less) high, 6 feet wide but only 8 feet (1.5 less) long. It held 2 adults and had a 5 hp motor. That one wasn't even glassed, just screwed together.
Fracking is good.
Old 04-20-2012, 11:00 AM
hoytedow's Avatar
Wood Butcher
Originally Posted by Submarine Tom View Post
Let me reword that.
Resting, about 11 inches if hull is level. Coaming may be added which will enhance free-board.
Fracking is good.
Old 04-20-2012, 11:06 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 2229 Posts: 2,696
Let me reword that.
It depends on whether he takes 2 of each animal, or whether 7 of some creatures are required.
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
