  #211
Old 07-16-2012, 06:20 AM
Frosty Frosty is offline
Previous Member
Rep: 0 Posts: 0
It should only get a little bit wet, mainly on the bottom bit. If it gets wet on the top then this is very bad and you will then need to run around in a panik shouting loud and clearly things like -'-its sinking' or 'give me your bucket' and of course the old favorite ---'swim for it'.
  #212
Old 07-16-2012, 06:24 AM
hoytedow hoytedow is offline
Rep: 2206 Posts: 4,271
Or "It's raining!".
Hoyt
The TITANIC sank because it had a hole in it(still does). Submarine Tom
You just can't put too much info on your patterns. DGreenwood
  #213
We don't want to have to "swim for it". Too many http://www.boatdesign.net/forums/pre...ors-43518.html.
Hoyt
  #214
Old 07-17-2012, 06:30 AM
Clue: Always make sure bearing on router laminte trimmer bit is well secured.
Epoxy impregnated sawdust makes a good patch.
Hoyt
  #215
Old 07-17-2012, 06:59 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2326 Posts: 4,254
Hi Frosty,
GLad to see you enjoyed you trip to home, now you can go back to Thai and pressurise them to become more like you
Hoyte, lots of ways to get more weight on them wheels if they's running too light...
Regards
Fanie
Water ! Just gimme water !
  #216
Old 07-17-2012, 08:08 AM
aka Terry Haines
Rep: 2144 Posts: 3,330
That's right up there with "don't feed meat to your power tools"
Dances with Turkeys
  #217
Old 07-17-2012, 09:19 AM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1210 Posts: 735
This could have been avoided by use of the ‘‘moaning chair’’ . . .
This guy got the message and put one up right next to his build . . .
And some work he does from the ‘‘work chair’’ . . .
Oh well, maybe you thought of that solution by use of the moaning chair . . .
Good luck !
Angel
  #218
Old 07-17-2012, 10:40 AM
Yep, but mine is just a plastic lawn chair. I find it very useful.
Hoyt
  #219
Old 07-17-2012, 11:37 AM
Previous Member
Rep: 0 Posts: 0
Ah the moaning chair. You know when some one says something and it all makes sense.
  #220
Old 07-17-2012, 12:02 PM
Angélique's Avatar
It ‘‘should be a comfortable seat’’ Chapelle said . . . .
Sitting on the wrong chair would give the wrong visions . . .
Good luck !
Angel
  #221
Old 07-17-2012, 12:13 PM
Previous Member
Rep: 0 Posts: 0
Getting close to desperation rather than moaning.
  #222
Old 07-17-2012, 01:12 PM
aka Terry Haines
Judging from the surprising amount of correspondence on the subject, a moaning chair is more important than I thought. I'd better get one . . . sounds like sitting on a portable worktable contemplating the flies in the epoxy pot doesn't count. How comfortable do I have to be to get the full benefit - should I move the beer fridge into the workshop as well?
Dances with Turkeys
  #223
Old 07-17-2012, 05:16 PM
Angélique's Avatar
Maybe the portable worktable is fine Terry, it depends on how flexible you are . . .
Chapelle didn't specify the drinks, so I guess anything that makes you comfortable would do . .
But maybe you need a ‘‘swear words book’’ if you don't know enough of them . . .
‘‘ Not the repair manual. Bring me the book of mechanics' curse words.’’
Cheers,
Angel
  #224
Old 07-17-2012, 11:41 PM
aka Terry Haines
Not quite that flexible! The worktable has one advantage, it has a built-in alarm, although not of the acoustic type.
. . . But maybe you need a ‘‘swear words book’’ if you don't know enough of them . . . . . . Cheers,
Angel
I think I may have contributed a lot of original and creative work to that book . . .
Dances with Turkeys
  #225
Old 07-20-2012, 12:40 PM
Rep: 1043 Posts: 1,720
Dammit Angelique, you have given us a link that will cost me money. I have to have the book titled ; Filthy English. I do believe that my vocabulary of profanity is more than adequate, however the book promises information about etymology and other interesting stuff. Sounds like a fun read.
