#151
| There you go, Hoyt, a brand new avatar! Now say thank you nicely . . .
#152
| Thank you nicely, Angel. ![]()
__________________ Hoyt The TITANIC sank because it had a hole in it(still does). Submarine Tom You just can't put too much info on your patterns. DGreenwood |
#153
| Any progress on the little cat? Hoyt,how do you plan on attaching the deck???? |
#154
![]() P.S. - Or maybe there are additional questions . . ? ? Quote:
![]() Cheers, Angel |
#155
#156
| I just bought the hull carrier components. I will post pictures after I have it built. It is basically a beefed up canoe carrier.
#157
#158
So no cross beams? I like the simplicty, wonder too how you think the bow will perform in the chop? |
#159
| Cross beams, yes, called akas, shown in white on drawing. ![]()
#160
| In chop it will go slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap slap. ![]()
#161
| Then you certainly have my permission to name it Wavewacker! ![]() That's okay if ya don't and it does, I still like it. |
#162
| Looks very good with the akas. Did you ever think about extending the beams beyond the hulls and adding a board from forward aka to the rear ? Might gain a lot of sitting comfort and safety. On the other side - a boat is not a settee. |
#163
| Thanks, Manfred. I am not considering making the akas wider to provide seating. Seating will be provided after basic hull assembly has been completed. Many small details are still to be worked out such as below decks access, battery placement and so forth. The little boat is already set to be 6 feet(1.83 metres) wide. That is wide enough for a motor-powered boat only 9.5 feet(2.9 metres) long.
#164
| This is the hull dolly:
#165
| Kinda reminds me of that old song hull-o-dolly... Nicely done there Hoyt. |
