Old 03-12-2008, 10:07 PM
afrhydro's Avatar
afrhydro afrhydro is offline
Rep: 240 Posts: 243
team looking to set a new record
http://sports.webshots.com/video/309...91848696aMbTVW
http://sports.webshots.com/video/305...91848696dvVsFc
we have a small team coming together to make this happen with a
v6 outboard
any in put would be of great help
we do want to stay with a hydroplane design so we can fly the boat on the prop
thanks
scott
Old 03-12-2008, 10:21 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Search here for threads on speed records, there are a few, and some good links to other good sources. If the small group includes someone who knows firsthand about ultra high speed props, you'll be well on your way.
Good luck!
Best,
Charlie
Old 03-12-2008, 10:31 PM
Just noticed your location. There may be some retired or laid off Mercury Marine techs in your area, from the former test facility in Placida, near the road to the Boca Grande causeway on Cape Haze. Maybe even a prop man.
Best,
Charlie
Old 03-12-2008, 11:56 PM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Hydroplanes
http://www.liquidquik.com/liquidwhatsnew/news.htm
Check out Dan Ellison's outrigger designs.
Old 03-13-2008, 07:06 PM
afrhydro's Avatar
Rep: 240 Posts: 243
i have seen that boat run
and have seen it have big time handing issues
we need something that gets more and more stable as the speed comes
and as stream line as a dart with as little drag as possible
both hydro and airo
Old 03-13-2008, 07:26 PM
Rep: 84 Posts: 294
both hydro and airo
The Liquid Quik has survived mechanical failures that would've crashed a Deaver type drag hull.
Old 03-13-2008, 07:32 PM
afrhydro's Avatar
Rep: 240 Posts: 243
im just not sure if it will work as a outboard boat
team looking to set a new record-35509355248.jpg  team looking to set a new record-820-10a-28cropped-29.jpg
Old 03-13-2008, 07:37 PM
Rep: 84 Posts: 294
Other Hulls
At this point I don't think there are any right or wrong answers, so Grand Prix/Formula One type tunnel hulls are also another option to consider.
Old 03-13-2008, 08:00 PM
afrhydro's Avatar
Rep: 240 Posts: 243
yea we thought of that one as well
17' 18 tunnels are limited to around 150 or so then they tend to blow over
its not going to be easy
looks like the team may buy a boat instead of build it so that puts me on the side lines
for now
Old 03-13-2008, 09:51 PM
rambat rambat is offline
Member at large
Rep: 124 Posts: 88
Venturi effect
We broke and held a world Kilo record with this wooden, low profile cat. We had 8 mercury 200 outboard power heads mated to two speed masters. Your goal can be reached with a smaller version hull and single 650hp outboard. Consider building a wide, low platform with a narrow airtight cockpit (safety capsule w chute). We got this up to 150mph but the daisy chained 2 stroke engine rpms could never be sync'd and usually tore up the aft most power heads on the drawdown. The driver, Bill Serois, told me it was very squirrelly and hard to control up to about 100mph, after that the slipstream started a venturi effect in the tunnel. This is the same effect the Indy cars use to stick to the road. It drove like it was on rails after that took effect and he felt it had a lot more speed in it if we could have solved the engine/sync issue. It sounds counter intuitive but the boat proved down force is good for calm water speed runs, make the cross over section joining the twin hulls an upside down airfoil and set the thrust angle to run the hull flat. At those speeds in a light/small hull you want suction, not lift on the body. The keels act like rails on ice over 100, its too fast to push down into the water. You will need long shallow strakes aft to keep it from barn-dooring in a turn.
rambat
Old 03-14-2008, 09:56 PM
afrhydro's Avatar
Rep: 240 Posts: 243
we been playing with this one a little
fashined after a f-15 eagle
i got to cut the sponsons down a little yet
plus if this plane can land with one wing it just might make a real fast boat
http://www.youtube.com/watch?v=-_EXtBEaBbs
team looking to set a new record-picture-475.jpg  team looking to set a new record-picture-477.jpg
Old 04-27-2008, 07:07 AM
afrhydro's Avatar
Rep: 240 Posts: 243
well it look like this project got scaped due to lack of funds
oh well
they all quit on me before we even got started good
Old 04-30-2008, 08:52 PM
Dan Ellison Dan Ellison is offline
Rep: 61 Posts: 56
kudos bro
i didnt mean anything by that statement
perhaps i should have said that another way
i have seen that boat make some great passes
and just like you said we all have our good days and bad days
I deleted my previous post, Boat can speek for itself, good luck with your attempt and let me know if I can help in any way.
Old 04-30-2008, 09:00 PM
afrhydro's Avatar
Rep: 240 Posts: 243
thanks dan
i could sure use some help with my electric propulsion deal
i was trying way to be way to greedy on the prop
14 34 12 29
i got a 12 16 two blade i want to try next
none of the guys want to risk a motor for the other speed record
with the outboard
so im back to my electric power
if i can get my hands on some decent batteries i think i got it or at least it will plane off and run
its all baby steps to you get going
www.allfiberglassrepairs.com
contact me any time
i got some great drawings
i just designed a new one tonight
Old 04-30-2008, 10:19 PM
Jimboat's Avatar
Jimboat Jimboat is offline
Rep: 113 Posts: 189
rambat is right....a tunnel won't "blow over" if it is designed for the intended speed. tunnels can be dynamically stable...designing for stability through the transition velocities are challenging for all hull types, but tunnels have enough controllable parameters to make it possible....just needs to be done! And making a 100mph boat design go 150mph is always going to be a formula for disaster....must be designed for the speed range intended.
Need a Design/Engineering Team? shalvers Services & Employment 5 12-06-2007 11:39 AM
Team of boat builders is currently available! W&O-BoatBuilder Services & Employment 0 06-27-2006 03:07 PM
Team Philips Catamaran steve66 Materials 17 09-01-2004 04:00 PM
Gitana Team Ilan Voyager Boat Design 8 08-31-2004 12:28 AM
Team Philips Daints_99 Sailboats 1 10-28-2002 07:41 PM
