| Teak transom Hi there, Can any one tell me where I can get some info on how to install a teak transom and a teak deck in a boat. Also where can I some info on the mezzanine material any information will be highly appreciated. |
| Melamine is the material I think you mean and it's used primarily in land based cabinet making. It's a durable thermoset plastic that is affixed to particle board (typically). For this reason it's not useful in marine applications, as it will literally fall apart after a short time. The surface material (the molded plastic resin) will stay intact, but the substrate will break down very quickly. Teak decking as well as other forms of conventional planking are covered in a few different texts, though like much of everything in yacht construction, requires several different skills to apply. It would be nice if each element, technique and method would have it's own reference manual, but in most cases they are generally covered in books about boat building or construction. This site has many previous posts about teak decks and carvel planking (your teak transom) and a search would prove fruitful. |
| What sort of boat is it, frp or timber. They both have entirely different ways to do the job.
| Teak or Mahogany?? | gerhern | Wooden Boat Building and Restoration | 2 | 10-31-2007 12:11 PM |
| using IPE instead of teak | fishweed | Wooden Boat Building and Restoration | 28 | 02-06-2007 08:03 AM |
| Teak Decks | aitchem | Sailboats | 16 | 01-17-2007 08:18 AM |
| gluing teak | dsmolar | Fiberglass and Composite Boat Building | 8 | 02-24-2006 03:22 AM |
| teak minus teak plus | seattle lite | Materials | 1 | 04-02-2005 02:36 PM |
