Old 11-03-2009, 05:22 PM
gow153 gow153 is offline
Rep: 10 Posts: 7
Take at this water line, what do you think?
There is a Bateau design Maia 24 for sale on Ebay now.
http://cgi.ebay.com/ebaymotors/2008-...mZ160374308391
It looks like it sits really high in the water, what do you guys think?
Old 11-03-2009, 05:36 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
It appears to sit high but some hard-chined boats will look that way. The boat may also be in light condition, with no fuel, water, stores, and crew. It's hard to say. Often a well designed cruiser will sit rather high until loaded, indicating that the boat has a good carrying capacity for extended cruising.
Most important is that it was designed by a knowledgable designer, something you should investigate.
Old 11-03-2009, 08:19 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
Jacques and Joel are very approachable, call them.
Old 11-03-2009, 10:10 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
If it handles as well as claimed, it should be a steal. That is a big if from what I can see. It looks like it will be very tender and I doubt ballast will make it a lot better. For everyone's sake, I would hope to be wrong, but that is what I see.
Tom Lathrop
Old 11-03-2009, 10:35 PM
Rep: 46 Posts: 173
What I know about the design, that is her load water line as seen in the picture on ebay.
Old 11-04-2009, 11:43 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
Take at this water line, what do you think?-bcqf-5gbmk-kgrhqiokk-eq32pjqccbkzokt-h6w-_35.jpg
The trim in the photo is far different than the trim in the drawing, this may just be the 400+ pounds of people in the cockpit. This will be the problem with any hull this fine aft, trim will be excessive as people move around.
Perhaps it could be mitigated with movement of the fuel, I don't know where the tanks are in this boat, hopefully below the sole. It looks like they could be moved forward to correct the static trim. But this will decrease the waterplane area aft, decreasing stability and increasing trim problems as folks move around the boat.
Take at this water line, what do you think?-bcqgwiw-2k-kgrhqmoki8eq4-0wovkbkzol-4pg-_35.jpg
She looks really unhappy, too high and narrow. Adding 600-1000 pounds forward of the main bulkhead might help.
Vertical height is directly related to beam, especially waterline beam. It's easy to forget when drawing the profile.
Current bid is at $5500, the motor is probably worth that.
Water line Devooo Multihulls 1 03-07-2008 05:42 AM
Below the water line Q-cell? Whale1 Materials 6 02-23-2008 09:19 PM
Sandblasting from the water line on down only. AdamFrench Metal Boat Building 3 05-24-2007 05:16 PM
Water line coating Sander Rave Materials 2 04-11-2006 04:21 AM
How to calculate balast ratio/ water line Ian Farnell Boat Design 6 10-07-2005 01:44 PM
