| Swimming platform lift system I woonder if someone can recommend good hydraulic lift system for swimming platform, for big boat. Thanks. |
| G'day Alik, No I don't, but I would be interested to know how and where you would fit one. Poida |
| Should be here: http://www.boatdesign.net/gallery/sh...00/ppuser/1473 |
| Poida you forgot to ask why, so I will,----why. Is this a swim platform that lowers a swimmer into the water gently and then recovers them when they have finished. The mind boggles. Is this for incapacitated/ geriatric/ obese swimmers? Or people who are too rich to climb a ladder. |
Luv ya work! Really,its a front. swimmers? Or heavy contraband? ![]() Maybe his transom is 10' high. Pretty hard too lift scuba up a 10' vert cliff. |
| Alik are we talking vertical lift or rotating up. Most have to be engineered to the transom of the boat in question. |
| I mean vertical lift. |
| What does it have to lift? Tender? etc?, If so what sort of weight?
| To manufacture something like this as a bolt on or even build in would be unlikey to fit another. So many variations in dimension. However at the Marina where I am at the top of malacca straits I see many super yachts on there way around the world or passaging to East -West. I have noticed that they usually have wonderfull access to the sea from the stern. In some case maybe only 6 inches. My attention was attracted to this because I would imagine this area would be totaly awash at sea. A vertical lift on these large ones I have not seen. There is one in the 50 foot range that has a lift with a RIB on it and I have to say that it looks ugly on this boat. Most super yachts lift/crane the RIB's boats of all descriptions up and onto the deck. You wouldnt want to maintain something on the transom whilst on the way. |
| Have to lift jet ski, or be lowered down to provide easy from water access for divers. This is customer's requirement, not ours We will have a crane for RIB also. |
| There's nothing uncommon in this - and given the opportunity, I'd certainly include a 'lift' on my stern... (Don't even think it Frosty...) There are any number of manufacturers - http://www.floridabowthrusters.com/swimplatforms.htm I think supply Searay http://www.tntlifts.com/ are one of the better known ones http://www.nauticexpo.com/scripts/go_to_web.php is another, though I've not seen these particular ones before
__________________ Will Imaginocean Yacht Design Logic will get you from A to B... Imaginocean will take you everywhere else... www.imaginocean.net Last edited by Willallison : 07-05-2007 at 01:19 AM. Reason: Frosty! |
| Thanks! |
| Right got it now. So it only has a lift of 300 - 400mm, just below to just above the water line. I thought you wanted something that was going to raise right up to the top of the transom. Will your last link didn't work for me. Poida |
| Oh --I was thinking of bigger boats. The last super yacht I saw come in was a boat called "Senses" her stern end/ transom collapsed to accomodate a 40 foot nelson that drove up inside it. She had a two sailing yachts on the top deck and stuff i forget down on the first. And a helecopter. |
| hi guy's, i've seen that searay platform demonstrated on a show and liked it. one of the motor supercats had a huge platform lifting from sciccor like jacks on the hulls. to lift only a jetski up there are systems that work separate from under and after the platform. |
| Floating Pump Platform Design | SWomack | Boat Design | 24 | 10-16-2011 03:13 AM |
| Propulsion question of a different sort. Swimming | Quilbilly1 | Propulsion | 1 | 03-25-2007 12:31 PM |
| Installing a swim platform | awol46 | Wooden Boat Building and Restoration | 11 | 01-02-2007 05:12 AM |
| SWATH work platform | waterballast | Boat Design | 4 | 12-21-2005 12:31 PM |
| Hovercraft dive platform | Moosen | Boat Design | 8 | 09-12-2005 06:49 PM |
