| Swash What should I look for in a boat design that will limit swash? |
| What is swash? |
| Cyclops, it is something that pirates used to buckle. With the recent upsurge in piracy, folks want to minimise it as much as possible. ![]() Actually - it is a British freshwater-ism for "wake" (I kid you not...) Steve |
A flat bottom 26'6" x 4'3" describes a Bolger "Sneakeasy" very small wake at displacement speed. http://www.psnw.com/~jmrudholm/sneakeasy.html |
| I love swash boats of 5 to 1 or greater. |
| Fine entry and minimal transom area can also help, in addition to the factors mentioned already. A canoe, even when pushed slightly beyond hull speed, still makes almost no wake- thanks to 5:1 to 8:1 length:beam ratios, and very fine bow and stern that cut the water smoothly and allow it to come back together smoothly behind the boat.
| Minimum deadrise, almost a flat aft..... |
