Old 04-25-2011, 10:32 AM
floating floating is offline
Rep: 10 Posts: 25
Survival load on mast or antenna
I have a question related to the survival of a slender tall structure mounted on a 'vessel' which is compliant with the waves, i.e. pitching and moving a lot. You can think of the structure as a mast on a small ship but actually is is a large antenna on top of a buoy. Waves are very high and steep (survival conditions). I believe the worst-case scenario is a breaking wave hitting the mast from the side, producing high pressure along the mast. Here's my question: Does this peak pressure move vertically along the mast, resulting in a time delay similar to the delay of a pressure pulse along the deck of a ship when it slams into the sea surface? Or is the pulse applied simultaneously along the whole length of the mast?
Also is there a 'bible' text that covers mast design for small ships? It's not my area (as this question makes clear), so I'd like to get oriented.
Old 04-26-2011, 05:31 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
I think it is the momentum of the buoy when it suddenly changes angle and position while hit by a wave. With a rigidly mounted antenna the base is loaded twice with every wave, first when the buoy heels, then when the antenna decelerates to a new position.
An antenna mast is normally a small surface compared to the buoy body and when hit by a breaking wave, the load is in the direction of movement.
I would make the base either very sturdy or mount the antenna on a spring or rubber element to soften the blows.
Old 04-26-2011, 05:42 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1925 Posts: 3,025
Any dynamics book on naval architecture.
You can get some basic info here:
Wave slap load on antenna
Old 04-30-2011, 05:31 AM
Rep: 1493 Posts: 7,447
The math for a dynamic situation like that is fairly complicated. If you need an antenna for those conditions, you can call the manufacturers with the specifications. They can tell you if their product is designed for it.
Wave slap load on antenna floating Boat Design 12 12-18-2010 05:13 PM
Load cell in the mast step to measure compression??? Gilbert Sailboats 4 11-13-2009 04:30 PM
mast mounted antenna externally mounted coax soundshooter OnBoard Electronics & Controls 3 03-26-2007 03:58 PM
mast design wave load french44 Boat Design 2 04-17-2006 04:50 PM
mast load nemo Sailboats 13 08-21-2003 08:14 PM
