Old 11-24-2010, 10:42 PM
kapnD kapnD is offline
Rep: 19 Posts: 143
Nikezz
If your mysteriously unstated objective is to avoid striking floating logs or debris, a good set of eyes on the bridge and a prudent throttle hand will not be replaced by technology.
If you are looking for something that you put in the water, ie drug smugglers or longliners, their preferred method is a transponder operating on a private frequency.
Commercial tuna harvesters have all but replaced their helicopters with aimable transducer fishfinders, some of which are worth much more than my entire boat!
The transducer is similar to an upside down periscope, gyrostabilized, rotating, and can be withdrawn into the hull for protection/cleaning when not in use.
Keep your eye on Simrad for more affordable versions rumored to be in the works.
Old 11-24-2010, 11:10 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Originally Posted by nikezz View Post
I like the side scanning sonar. What I've seen so far are SS sonar that tend to be used for deep depths, for high resolution images. However, I haven't come across one that looks closely at the surface. Do you have one you can recommend? Does your prototype work just under surfaces?
Any will do the trick just turn the transducer facing the direction you wan't (forward I quess) Needs a bit of imagination how that can be intrepreted on the screen but anyways..
There are of course also forward looking sonars like Interphase and Echopilot thou I don't have any experience of them..
Old 11-25-2010, 03:04 AM
pool pool is offline
Rep: 38 Posts: 47
I know about radar. It is not what I am looking for.
The best analogy I can think of is an iceberg. I am not looking for the tiny tip, I am looking for the hidden section located under the water. However, said iceberg is not vertically long on length nor is it huge. It's just under the surface of the water. Alternatively, think of broken debris that can float on the surface with almost nothing sticking out. Small above water, slightly bigger under water.
this one www.farsounder.com could do the job, but it's big $$$.
I once had an Interphase installed - not very happy with performance, but was an early model.
Old 11-25-2010, 03:12 AM
Rep: 670 Posts: 2,457
I would think that the big challenge for surface sonar would be interpreting the echo. To much back scatter and to many " hear then gone " targets. Would require some sophisticated software..perhaps multiple echo frequencies and a very powerful output
Old 11-25-2010, 10:03 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
No different from clutter suppression on a radar. A radar is looking at the surface of the water and gets a lot of echo from transient wave faces. What the OP is talking about is exactly the same thing, just from the underside. Would work well for detecting saturated logs or containers or such.
Old 11-26-2010, 01:18 AM
Perhaps...I have an aft facing sonar . The vessel has a 3 meter deep rudder and backing into stuff in ports is a concern. The signal from this sonar gets wiped clean with propwash and takes up to 30 seconds to recover. I would think the same wash phenomenon happens on the surface layer of the sea as waves roll and break and the water mixes. Perhaps they have strategies to overcome this ..
Old 11-26-2010, 10:43 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Or maybe the OP is not making way when using the device. We don't know because his/her intensions are a secret...
-Tom
Old 11-26-2010, 01:58 PM
apex1
LOL...........
So you professional yacht "Captain" have a device installed which becomes worthless when required. Clever, no doubt.
BTW. sonar it is most likely not. A sounder maybe, but I doubt you have a boat, let alone the equipment.
To the Op´s question:
a radar is what provides your requirement, not a sounder. (a sonar you will most likely not afford)
Both have a very nice restriction, they do not like to operate in the wrong environment. A radar will not let you look into the water, and a sounder not into the air.
Unfortunately, the boundary layer is not as stable as one would like. So, sometimes your "target" is not as detectable as you would like it.
If I were in your shoes, I would not think about drug traffic with our assistance. There is no nautical demand to know targets invisible on surface, but A FEW CENTIMETER BELOW! A hard driven foiler may have a somewhat similar requirement, but you have never heard about a foil.
Go, and find another source of info, Arschloch.
Peers,
I like your professional attempt to assist, but have you thought about the requirement of this "member" ? go figure..
Regards
Richard
Old 11-28-2010, 06:35 PM
nikezz nikezz is offline
Rep: 12 Posts: 35
-Tom
We are making way, except we might be moving a bit slowly, like less than 5 knots.
  #25
Old 11-28-2010, 06:47 PM
Rep: 12 Posts: 35
Originally Posted by apex1 View Post
LOL...........
Peers,
Regards
Richard
Hey, if you don't wish to help, there is no need to. If you just want to troll and be a steamer, please find some other thread.
Do you have too much free time and angst in you?
All others, thank you for your helpful and please ignore the rude and non-helpful posts by apex1.
  #26
Old 11-28-2010, 09:16 PM
Mariner
Oh boy, here we go again, so much for this thread.
Bye-Bye
-Tom
  #27
Old 11-28-2010, 10:06 PM
cthippo's Avatar
Rep: 452 Posts: 725
Bye-Bye
-Tom
Yeah, pretty much. Should be entertaining though
  #28
Old 11-30-2010, 10:12 AM
apex1
So what did you require?
A non sensible and non available sort of equipment, to fit a non sensible and not required sort of SOR in general yachting, shipping, and naval industry.
If you would have been a bit less "virgin" with your SOR, you might have got more than some broad hints, like CDK´s. But you have choosen to hide your requirement. That makes a sensible contribution impossible. Troll? you are the troll, you have not got my last post!
My rant about the "professional Yacht Captain" is another pot of fish isn´t it?
KMA
Richard
  #29
Old 11-30-2010, 05:18 PM
Rep: 12 Posts: 35
End of thread.
  #30
Old 12-04-2010, 07:42 AM
apex1
End of thread.
Ahh,
you mean you did not receive the applause expected, and now you spread a bit hatred and leave the place?
thanks for your comment per feedback:
Spends more time trolling rather than helping. Makes general statements such as "there is no nautical demand" without thinking first.
You should have thought about the sense of such a "gimmick", before you asked here!
new Echopilot vs. Farsounder 3D forward looking sonar expedition OnBoard Electronics & Controls 8 01-12-2011 11:46 AM
Side scan sonar Asleep Helmsman OnBoard Electronics & Controls 25 01-29-2010 05:23 AM
Redundant Sonar / Depth Finders and Bilge Pumps ChrisN67 OnBoard Electronics & Controls 0 02-16-2009 04:56 PM
Forward Looking Sonar Pericles OnBoard Electronics & Controls 3 12-17-2007 10:24 PM
Sonar modification noledoc Sailboats 1 06-19-2007 05:50 PM
