Old 05-08-2008, 02:47 AM
Panos_na's Avatar
Panos_na Panos_na is offline
Yacht designer - Student
Rep: 10 Posts: 60
Surface smoothness
In the windsurf industry, some boards have a nery smooth hull and others have a hull surface which is mat.
My question is, how much does the hull surface smoothness affect the resistance, boundary layer, etc?
Some say that the mat surface has better performance, while some others insist that a very smooth surface is better.
I think that everything has to do with laminar flow, turbulent flow, boundary layer, etc.
Can someone give me more information..?
Old 05-08-2008, 12:20 PM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 451 Posts: 506
Golf....
http://ffden-2.phys.uaf.edu/211_fall...ts/flight.html
Now, joke aside, some of the physics that are valid for a golf ball will probably be valid for a board too. But then they wax the boards and I've never heard about anybody waxing their balls.... (Now I got the wrong picture...)......
KnutS
"it's dark and we're wearing sunglasses"
Old 05-12-2008, 04:11 AM
kazik_four's Avatar
kazik_four kazik_four is offline
Rep: 15 Posts: 1
is it smooth enough
There`s some information you were searched. It is common but useful
http://www.sailtoronto.com/racetraining/bottom.pdf
Old 05-12-2008, 10:23 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Nice paper on the topic, thanks for posting it.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 05-12-2008, 05:40 PM
Knut Sand's Avatar
Rep: 451 Posts: 506
But that paper want the hull to be without dents, some theories I've heard say that at planing speed or above, you get air under the board, the bubbles get trapped in the dimples and dents, redusing the wetted surface, and therefore the friction. However I agree that a smooth surface is the best alround solution, as the dimples will probably have quite the oposite effect (to be read as "a brake") at speeds outside the optimum, with regard to speed and waves.
KnutS
Old 05-13-2008, 10:30 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by Knut Sand View Post
But that paper want the hull to be without dents, some theories I've heard say that at planing speed or above, you get air under the board, the bubbles get trapped in the dimples and dents, redusing the wetted surface, and therefore the friction. ...
It's also been said that air bubbles stuck to the surface are bumps that increase the drag, hence the concern about wetting or not wetting the surface.
In "High Performance Sailing," Frank Bethwaite reports the tests he did towing full scale planing dinghies to measure the effect of different surface preparations. His finding was the bottom cannot be too smooth. Polished is better than anything else.
Tom Speer
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
How much planing surface do I need? kengrome Powerboats 5 10-22-2007 05:02 PM
NURBS surface suhoi Software 0 07-06-2005 02:21 PM
3D Surface Help lazza Software 1 06-05-2005 01:46 PM
Maxsurf Surface Help quicksail Software 1 05-05-2005 09:32 AM
