| surface piercing propellers How can build surface piercing propellers?Can use Nibral for this propellers?What standard suitable for this? |
| have a look on ROLLA PROPELLERS web site. He is the most popular and famous piercing propellers manufacturer. |
| I am looking for reference material regarding methods for evaluating the vertical forces generated by a surface piercing propeller by various combinations of Pitch,Rake,Skew,blade and hub design. Is there any openly published material? Thanks. |
| So detailed open water tests, I don't have never see. I think that one of the problems is that the thrust direction has the possibility to be modified. I had a Dos program from Arneson that permit to calculate the resistance and the propulsion (optimization of prop. geometry) of high speed boats. The name of the program was AMI.BOAT that permits to calculate D, P/D, n, Eta0... try asking Arneson.. Some material has been published from Rolla , ask directly using e-mail in web |
| Thanks Otto, I'll do that. |
| We are both graduated from the Westlawn...... |
| Yes we are!! I am very impressed with your work! it looks very exciting. |
| Yes, it is.. Thank you... Exiting is to give garantee for speed for military boats... All designs btw. 40 and 50 knots... Penalty if you reach 1/2 knot less and with 2 knots they refuse the boats!!! This means that the shipyard is out... Exiting...yes ! |
http://www.well.com/user/pk/SPApower.html |
| Eureka ! It's the same..bravo Jeff!! |
| Thanks guys!! |
| With this program you have the possibility to calculate your curve of piercing screw r.p.m. plotting, once D, P/D, z choosen, using coeff KT/J^2. You have the possibility to construct open water curves using this wonderful program.... |
| good info, thanks guys ![]() |
| Thanks.... from my friend Sid Nixon.... he like it... ![]() |
| Best shape for surface piercing foil | grob | Sailboats | 48 | 11-23-2010 05:47 PM |
| efficiency of surface drives and surface piercing propellers | David Knight | Powerboats | 7 | 09-24-2009 05:10 PM |
| Surface piercing propeller characteristics | manunk | Boat Design | 3 | 06-28-2005 03:12 PM |
| Seafury surface piercing drive setup | ralphfdill | Surface Drives | 3 | 06-20-2005 01:24 AM |
| Surface Piercing Props | gyrojocky | Props | 22 | 12-10-2004 08:50 PM |
