Old 08-31-2011, 02:12 PM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
supply- stability-structure
dear all,
I,m Ricard, a italian student;
for my project I have to settle on a supply vessel a crane, what must I do to limit the maximum distance and maximum angle of the crane?
from the point of view of the structure what should I expect?
how must i verify a new stability?
Many thanks in advance
Best Regards
Old 08-31-2011, 02:17 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
What capacity is the vessel? What is the crane expected to lift? You are very vague in your questions. Even crude drawings help tremendously.
All you need to know is in standard engineering texts.
Old 08-31-2011, 02:52 PM
Rep: 1758 Posts: 1,561
Shipboard crane rule #1....The suspended load is applied as if it's mass and CG is at the upper sheave box axle. After that everything falls out (as Bataan said) from the standard engineering/stability texts which will include dynamic seaway loads due to roll, pitch, and yaw.
24 volts from a 12 volt supply Mat-C OnBoard Electronics & Controls 17 09-05-2011 07:59 AM
Cuba Supply Vessel brian eiland Boat Design 15 01-28-2009 11:08 PM
Epoxy supply in RSA? Manie B Materials 13 12-18-2008 11:53 AM
FSC wood certified - supply alexandros Materials 0 02-16-2008 04:40 AM
supply metal mesh zhujie Metal Boat Building 0 02-24-2004 08:13 PM
