| Sunfish Conversion? Hey all this is a great looking forum. I got a few questions about a project i am about to take on.. I am a waterfowler and i just aquired an older alcort sunfish sailboat hull only. my plan is to convert it into a barnegat bay sneakbox. i know this conversion has been done before but i can not find any info on the subject. also for power i was thinking of gutting and transplanting the innards of this old jet ski that i have (thats right jet powered sunfish) i wasnt sure if this should have been posted in the sailboat forum or this one. but if anyone has any ideas for a sailboat conversion i am open to all suggestions.. thanks in advance. |
| Rowdy (by name as well as by nature?), I would advise against the jet-ski conversion unless you want to scare the ducks to death. Not sporting. Instead, why not a nice short-shaft trolling motor, with a big battery? That should push you along nicely, and be cheaper to run as well. The thing is, the Sunfish hull is just plain the wrong shape to take a powerful jet well. Too much rocker means that the only way to keep the intake "planted" will be to run at an angle of 10-15 degrees or so. A good recipe for flying lessons at speed in that thing ![]() You might also consider the traditional solution - a large sculling oar over the stern. Lie back in the boat (well, as much as you can in a sunfish) and have the sculling oar over your shoulder. That said, if you are sold on the jet drive, have fun but don't say you weren't warned... Steve |
| Rowdy; Do yourself a favor by forgetting the jetski/Sunfish idea. I know the Sunfish well , having sailed them extensively. Sometimes over rigged with a Hobie 14 sail and other absurdities. It would make a decent waterfoul boat but it will accept,maybe, two horsepower and you wont use both of them. Take the other guys advice and use a small electric motor with a big battery. Good luck = low power. Regards Sandspur |
| Trolling Motor I agree with the idia of puting in a trolling moter. You may be able to mount it on the existing rudder brackets. Also, on the deck consider puting flexable solor panals to charge the baterys. Maybe even keep a smaller sail to asist the motor for longer trips. Just don't put a 100hp jet drive in. Hope it comes out well. ![]() |
| Inboard to outboard conversion | James Francis | Fiberglass and Composite Boat Building | 16 | 06-28-2007 01:46 PM |
| Outboard conversion on displacement hull | Allan | Powerboats | 7 | 09-13-2005 08:53 PM |
| AutoCAD design/drafting, raster to vector conversion. Vectorization old plans... | Spep11 | Services & Employment | 1 | 07-13-2005 06:12 AM |
| Fishboat Conversion | Powerboats | 19 | 08-03-2004 11:43 AM | |
| Conversion or ???? | Dogpaddle | Boatbuilding | 8 | 08-06-2003 09:30 AM |
