Old 12-20-2006, 10:17 AM
fradrigo fradrigo is offline
Rep: 10 Posts: 23
...summer load waterline...
...what is the quickest way to calculate position of the summer load waterline? Any software or excel file available?
Thanks )
Old 12-20-2006, 12:48 PM
french44 french44 is offline
Rep: 63 Posts: 23
change the density water ,for sample atlantic sea water at 20 deg desentity is 1023 kg/m3 and at 30 deg density is 1020 kg/m3
Old 12-21-2006, 08:03 AM
Rep: 10 Posts: 23
...density allowances are one of many allowances and corrections that needs to be taken care of to calculate final position of the summer load waterline. I was looking for some software that could speed up the calculation a bit...why I need this ? Lloyd's, for example, based it's rule lenght on summer load waterline , and scantling calculations are directly dependent...vicious circle
Old 12-21-2006, 08:45 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
I bet a spreadsheet would be a useful tool in this. Do all your formulas at once referencing one or more cells with the variable(s) in them.
Steve
Old 12-22-2006, 08:44 AM
Rep: 10 Posts: 23
...here's some usefull guidelines ( although slow download )...
http://www.seamanship.co.uk/products...section_26.pdf
keel load, dynamics water addict Boat Design 0 02-28-2005 12:05 PM
Load carrying “Targa Bar” skedadle Fiberglass and Composite Boat Building 1 10-25-2004 04:09 AM
Jib sheet load Lutjanis Sailboats 1 02-23-2004 09:49 PM
heat load calculations thomask Software 1 11-12-2003 10:23 AM
mast load nemo Sailboats 13 08-21-2003 09:14 PM
