| 85 trophy bayliner transome i got tis boat from a freind and the inside plywood was already take out off the transome, i put a piece o 3/4" plwood back in and put a layer of mat and a layer of roven on it will that be enough for the transome or not? theres only a 4 cyl volvo and a 270 volvo leg goin back in ,and the motor mount are going to be done also, any advice would be great , thanks guys |
You would probably get more help if you started a thread in boatbuilding under fiberglass and composite boatbuilding. |
| Check out the Caribiana sea skiff. Built for open ocean, very smooth. I went for a test ride the day after a huricane came through. No slamming 20kts easy. |
| Small O/B v-hull....design suggestions? | pbplayer78 | Powerboats | 0 | 12-10-2007 08:52 PM |
| Rough seas stability: wide or narrow beam? | glastront156 | Boat Design | 12 | 02-18-2006 12:39 PM |
| Best handling small craft in rough water: V hull, Cat, Trimaran, Pantoon, PWC? | glastront156 | Boat Design | 14 | 02-08-2006 11:54 AM |
| New (possibly) idea for monohull stability in rough seas | sryth | Sailboats | 45 | 08-24-2005 05:41 PM |
| Overturn in Rough Seas | Haji K | Boat Design | 7 | 02-19-2005 04:20 AM |
