Old 11-05-2008, 08:27 PM
rasorinc rasorinc is online now
Rep: 682 Posts: 1,130
submersible aircraft
Would it be of interest to anyone to start a new thread on this subject?
After kind of laughing at the idea I set down some parameters and worked through a few quick problems and I believe it is possible using a maximum
depth of 80 meters or 9 bars of pressure. Stan
Old 11-05-2008, 11:39 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 511
I hear the aliens already have this technology.
Old 11-06-2008, 08:49 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
USO's, they have been on the history channel.
I'm no engineer, but admire the efforts of others even if it's just a mental exercise.
The efforts of this guy (Doug) and the process (shows his math) is impressive and might be a good reference point for this thread.
SEEKER - by Doug
http://www.submarineboat.com/submarine.htm
SEEKER is a hybrid diesel powered jet boat and ambient submarine.
These projects are cool too:
http://www.navytimes.com/news/2007/0...esigner070211/
http://www.hyper-sub.com/product.hs600m.php
Also, almost anything can be made to fly, or at least hover.
http://www.minimarcos.org.uk/altpics...ini/index.html
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 11-06-2008, 03:16 PM
Petros Petros is offline
Rep: 717 Posts: 764
They already have one, it was used on the "Seaview" TV show of the 1960s where they used the flying sub to patrol the area around the sub's location.
When in engineering school 25 years ago I did some calculation to see if this was possible. It might be if you had an efficient engine that did not need air to breath, and you had a "wet" sub. No way to make a dry sub work, way too heavy.
But even as a wet sub, it likely would not fly well, or make a very good sub. And it would have very limited range. It would be more piratical to have a fold-up ultra-lite aircraft on a minim sub.
Old 11-06-2008, 05:28 PM
Well It will work. It looks like a round bodied PBY though. Stan
Old 11-06-2008, 09:07 PM
big-boss big-boss is offline
Rep: 10 Posts: 58
I have thought about this as well, Civil Engineeer not a Naval like you guys. But give this some thought:
Start with a flying boat then make it submersible. Should be easy enough to make a boat fly then fill it with water, right?
Old 11-07-2008, 05:58 PM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Darpa
DARPA is serious about researching this concept as a means for delivering and recovering special ops personnel (seals).
Old 11-12-2008, 02:50 AM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
It's been done.
Here are some design factors to think about.
The issue of wet vs dry is of fundamental importance. Any buoyant volume is a hinderance when submerged, so dry space (if any) has to be kept to the bare minimum.
Fuel is less dense than water, so fuel volume contributes to buoyancy. And it contributes to weight when flying, so fuel quantity hurts you coming and going.
The implication of the two factors above mean it's the structural weight that has to be capable of overcoming the buoyancy of the fuel & payload. Then you have to carry that structural weight when you fly.
The alternative to negative buoyancy is to fly underwater with positive buoyancy. There's a drag associated with that, of course. But at least they already have a flying configuration. Underwater gliders have been used for exploration and unmanned oceanographic vehicles. A good example is the UW Seaglider.
Tom Speer
Old 11-12-2008, 12:38 PM
kach22i's Avatar
Architect
Now we are getting somewhere.
Good post.
Old 11-12-2008, 02:47 PM
Rep: 84 Posts: 294
Shapes
Originally Posted by tspeer View Post
It's been done.
I first saw that shape (minus the wings) back in the late sixties. There was an article in Science News about research being done by the navy on low drag shapes using both small buoyant bodies released from the bottom and streamlined projectiles dropped from the surface.
Old 11-25-2008, 01:55 PM
kach22i's Avatar
Architect
http://blog.wired.com/defense/planes...mps/index.html
Old 11-25-2008, 09:19 PM
markdrela markdrela is offline
Rep: 161 Posts: 119
I've never figured out what advantage is obtained by "gliding" underwater. In the absence of vertical currents, the minimum energy needed to travel is Drag*Distance, and it doesn't matter whether the energy is used to run a small prop, or to pump out water at the sea bottom to regain positive bouyancy for the return glide back to the surface. But when gliding, you're dragging the wing through the water in addition to the body/payload. It seems that removing the wings/pump, setting up for near-neutral buoyancy at all times, and installing an optimized propeller will give better mileage.
Old 11-26-2008, 03:47 AM
Retired Geek Retired Geek is offline
Rep: 14 Posts: 62
Flight Internationals Concept
this was posted on their website today (flightglobal.com)
Old 11-26-2008, 04:08 AM
rickthorn rickthorn is offline
Rep: 10 Posts: 20
Competition for Navy Contract
Within the past 2 weeks, I have heard the U.S. Navy is looking for a "flying submarine" of sorts for clandestine missions. Also, just thought the following is extremely cool...just needs a bit longer wings, more sleek design and more horsepower.
http://www.hovercraft.com/content/media/video/19xrw_04_256k_lo.wmv
Old 07-22-2009, 11:48 AM
Gannet's Avatar
Gannet Gannet is offline
Rep: 36 Posts: 36
I thought you would to see DARPA's BAA09-06 SUBMERSIBLE AIRCRAFT Proposers_Day_Presentation
http://www.darpa.mil/sto/solicitatio...esentation.pdf
aircraft carrier's stability phxysius Stability 16 04-29-2009 08:41 AM
Submersible Aircraft juiceclark Boat Design 21 11-04-2008 11:11 AM
Modern Aircraft Carrier Dook Boat Design 105 10-20-2007 08:14 AM
The Sikorsky Aircraft Gunboat kach22i Open Discussion: All Things Boats & Boating 9 01-17-2007 12:49 AM
Fantasy Aircraft kach22i Open Discussion: All Things Boats & Boating 11 02-10-2006 02:42 PM
