#121
#122
| ah, cutouts...what i am referring to as special load conditions. these concentrate loads in ways that do not compliment the strengths of concrete, typically calling for reinforcement to communicate the loads, typically more of a confinement issue with, for example, the ends of a support wall. thin members become impractical to fabricate where, again for example, converging steel reinforcement to a radial point as in a circular hatch creates geometry problems for the aggregate. |
#123
| The russian concrete submarine hulls use finely ground ceramic mixed with cement. No aggragate just a dense high strength mortar. They dont have steel in the mortar but do have a thick kevlar lining bonded to the inside. I think as soon as you start using embedded steel and coarse aggragates you rapidly increase the micro-cracking with each makor load cycle, this starts at aggragate boundaries and more importantly at the steel interface. Then there's the stress concentrations at those darned cutouts which will be the real bugbear. I had a quick look at the IES site It's not an ideal tool for this. Even then we are not analyzing Wlifrieds design since he simply doesn't give any detail. The russian design is fairly indicative of what is required for high pressure reliability.
#124
| roger that mike, good intel and thanks. kevlar is a big head-start. in your research with russian design, was their any reference or discussion of alkali silica reaction. ps. are your referencing the use of a depeleted uranium dioxide? |
#125
| No I was wondering about ASR, no reference to pozzolanic additives and I know nothing of ceramic-cement motars. The Russian mix is basically a high compressive strength; cheap and as close to an isoptropic material as they could manage. No Uranium dioxide either.
#126
| mike, you're dead-on with ies. crashed a model of the bow last night twice, sitting in a public hearing with a land use board while occasionally glancing up in agreement. i have to do it in panels but at this point i’ve answered my own questions with this exercise. wellmer, here's where i'm at with your proportions of 10cm shell thickness to 20m diameter unreinforced concrete submarine. 1. under submerged 30m service loads that you propose, the 10cm unreinforced shell does not work. deflection and cracking. solution is steel, and 30cm is the thinnest I could estimate with steel and membrane. an alternative is to pressurize the cabin but this imposes onerous operating restrictions that i imagine are contra to your objectives for a recreational application...the vessel would be more of a self-propelled commercial diving bell of sorts if pressurized. 2. under surface / dock conditions, steady sea state and gentle winds, the unreinforced vessel also does not work irrespective of practical shell thicknesses. requires skeletal structure and reinforcing steel both. keel / ribs and the need for these getting exacerbated with dynamic loads of a sea condition. special load conditions associated with cleats and cutouts are also problematic for unreinforced cases. could fabricate specialty docking saddles / cradles but that’s restrictive on where the vessel can dock. Cutouts work if there are steel bushings and frames attached to steel, and more analysis is needed as to where and how these assemblies are constructed. you need to be careful with load distributions and differential deflection, so not to cause cracking, leaks, etc. 3. under dry dock conditions, the unreinforced shell requires continuous bracing along bottom membrane with virtually zero deflection, which is impractical. with steel the upper sections need stringers with cribbing and blocking systems that are far more involved compared with a steel vessel, otherwise you will have extensive cracking in areas like the tower. one approach to cribbing might be to keep the formwork used during construction as the cribbing. the most challenging elements to support in dry dock will be the aft fins and screws, and forward or tower fins, as required. 4. under sea state conditions, regrettably i didn't get there with the model. the areas that i wanted to study were various sea conditions, effects of friction and wind, and vibration. willmer, as i reflect on this brief yet challenging exercise i have still more questions than answers on your project. you have embarked onto a fascinating topic in mechanics of materials and i have especially enjoyed the exchanges with mike johns. |
#127
| submarine yacht 18m status Now that raw hull building is almost finished i can share pictures and video. Get a look at Ian's Yacht Sub at: http://www.youtube.com/watch?v=zLv22CPYFSo ![]() Cheers, Wil Last edited by wellmer : 01-11-2009 at 08:22 PM. |
#128
| appears there is some hefty reinforcing steel in the exposed aft section and shell is considerably thicker than 10cm you had proposed earlier, what did you end up doing for a design? |
#129
Cheers, Wil |
#130
| what did you end up doing about vibration? |
#131
| I do not expect vibration to be an issue in this boat. Quote:
Concrete floating structures in marine ambient generally are supposed to take a order of million load cycles per year and have a service life of 100 years. In this conditions cycle load is considered a "non issue"... Cheers, Wil |
#132
| wil, i'm asking questions from the perspective of no knowledge of or experience with concrete submarines. outside of this thread i've never heard of such a thing. certainly opens the door for questions but you're responses are defensive and make little sense. you don't anticipate vibration to be an issue so you ignore it? 100 year service life? come on man, just be genuine. you've case a concrete vessel, that seems real enough, but the way you handle questions and back-track on your own assertions is confusing. i wish you much success with your project but it doesn't feel like that's where you're headed, not from the way you're communicating anyway. |
#133
Excuse me if my responses to attack are defensive... They should make sense to a open minded engineer...i get daily feedback from people for which my responses make a LOT of sense...i do not aspire to convince everybody who is out there...this would be a impossible task. I have heard and read about the "vibration issue" on nuke sub due to their building and speed carackteristics - fact is - i do not build a nuke sub, i do not speed like one - so the issue is a NON-issue, it was a non issue in the prototype and it will be a non issue in this boat based on the experience of the prototype. But i will test that out in detail and share the info with you. Honestly i think the basic problem is still that you seem still mentally entangled in the military sub segment. Yes, please update with the corresponding studies about load cycles on floating concrete structures in severe marine ambient... Sorry if i confuse you - i just try to get my project forward - if you are not on board for now that is sad - maybe we make another intent to get you on board a bit later when the boat is out and navigating. Cheers, Wil concretesubmarine.com |
#134
| i'm niether on board nor not on board wil and my sole wish for you is much success with your project. i'm not challenging or doubting your ambitions either, although i am again taken back by the tone of your postings. i don't design marine vehicles. i design and build buildings, bridges, etc and aside from the occaisional concrete tank or pier we don't encounter concrete submarines in my world. i simply don't know anything about them. and i found no light in taking some time to model the vessel you had proposed earlier. mathmatically you seem to be headed in the right direction with a thicker envelope and steel reinforcement and again, best of success to you and your project. |
#135
I know that if you look it sufficently detailed the problem can always be "made much more complicated" - but baseline is - a concrete tube with the characteristics i propose - submerged - calculates and models very well with a simple arch calculation that a first semester student can do with paper and pencil in a few minutes and was well understood by roman engineers some 2000 years ago. So there is absolutly no "rocket engineering" in the basics. If i can get a YES for the idea that it "might be structurally possible to submerge a concrete tube" i would like to take you to biology. - the submarine was not invented by the military it was invented 400 million years ago by mother nature. http://en.wikipedia.org/wiki/Nautilus ...pressure resistant (imploding at a depth of about 800 m) ... This little submarine has nothing else than a pressure resistant shell a biological water pump for bouancy control and a basic propulson and steering. Can we part from the hypothetical approach that ANYTHING a nautilus donīt have but a modern sub has, is basically a "military driven need" that has nothing to do with the requirements of just hang out in the ocean and pass well. If i could get a YES for this - we could start a interesting dialog about what a "nautilus like leisure boat for human ocupancy" would require. I would say a hull shape of this kind would be nice: video concrete submarine hull http://www.youtube.com/watch?v=zLv22CPYFSo My current submarine yacht project: ![]() I am working on it... Cheers, Wil |
| Submarine Project | kc135delta | Boat Design | 230 | 04-12-2010 08:25 PM |
| Unsinkable Yacht Project | Herry | Boat Design | 35 | 02-09-2007 02:54 AM |
| Yacht Building Project Manager looking for employment | George Mui | Metal Boat Building | 1 | 08-08-2006 10:30 AM |
| Mega-Yacht Project Manager - Position Wanted | Driftwood | Services & Employment | 0 | 03-04-2006 07:12 AM |
| Yacht Interior Project Managers (X2) | Daniel Fenton | Services & Employment | 0 | 10-31-2004 06:50 PM |
