#271
| Well I can't easily find it. The empirical results covering wall thickness vs diameter are described in the first paper I posted. Someone could check the features of the c303 pipe of interest to estimate external load bearing. |
#272
| You can choose quick, cheap and perfect. Pick any two. |
#273
| Thanks for taking the time to look for the paper. The other one is a great resource. |
#274
| I think the paper is on my work machine at the shop- I will check on monday.. |
#275
| I actually tried to work through the math, since the formulas are given to determin the wall thickness of concrete needed to withstand any given depth. But to be honest the math went way beyond me. In that paper they did discuss a concrete tube capped at each end that was left submerged at 500' for 10 months (I think it was), the dimensions on the pipe were 9" thick, by 120" diamater, by 10' long, capped with concrete hemispheres the same thickness of the tube.
| Boat Building Projects Underway | Manie B | Boatbuilding | 200 | 05-14-2012 01:15 AM |
| Route du Rhum Underway | cardsinplay | Multihulls | 184 | 11-28-2010 01:24 PM |
| Trailerable daysailor underway... | Wynand N | Boat Design | 40 | 12-01-2008 11:38 AM |
| loud knocking noise underway in gear | LEASEGUY | Outboards | 14 | 05-18-2008 10:45 PM |
| Job Search Underway | dantemclean | Services & Employment | 0 | 08-02-2004 07:50 PM |
