#91
| WIG - light? Quote:
#92
| From what you have said, you may also want to consider an air cushion landing system, also known as a hovercraft-WIG combination.
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
#93
| Power Required? I agree with you I also find WIGs a fantastic concept. Quote:
Another WIG approach you may find worth investigating is http://users.telenet.be/heliferry/Pr...of%20lift.html |
#94
Again I must protest large rotating blades near the water surface. I'm not going to lose my head over it in a pitch though. ![]()
#95
Check out "Secrets of Tunnel Hull Design" book, or various papers on web site. Call if you want to discuss. Cheers!
__________________ /Jimboat AeroMarine Research 'Secrets of Tunnel Boat Design' book 'History of Tunnel Boat Design' book 'Secrets of Propeller Design' book 'Tunnel Boat Design' software w/'Vee hull design' & 'Porpoise Analysis' 'PropWorks2' software 'Vee Hull & Vee Pad Design" paper 'BoatDesign.net article on Tunnel Boat Design" |
#96
| The design I have in my head is based around a tunnel (or catamaran?) hull type. The idea is to basically have a large WIG specific wing in the middle with tunnel type hulls on either end. I quite like the idea of a large ducted fan setup in the middle of the wing for WIG VTOL. The blades of the ducted fan could be variable pitch so that drag would be minimised once WIG flight is achieved. Would the rotation of the fan would provide a gyroscopic effect, aiding stability? |
#97
| BELT DRIVEN Counter Rotating Planetary Drive Units Now Available! Increase Thrust up to 30% Reduce Noise by up to 30% Use Wide or Narrow Propellers Front Propeller Turns Larger Slower Propeller to Feed Rear Faster Propeller. Available in (3) Combined Output Ratios: http://www.centurydrivesystemsinc.co...r_rotating.htm |
#98
| Purchaser of Flightship Quote:
Check this link: www.wigetworks.com They are still operational. I am currently in communication with them. Cheers |
#99
| http://www.youtube.com/watch?v=SJaOb...mbedded#at=293 follow this link to see the only good wig plane design, other than my own. |
#100
| If i may add my input to stepped hulls, stay away from them when building WIG planes, you want a smooth and flat as possible surface, stepped hulls displaces water and interrupts the airflow around the foil that creates lift. |
#101
| rjbuljubasic@gm and what or where is your good wig plane design? the u-tube link seems to show a low flyer, but i'm only an amatuer enhousiast there are 3 types of wig i read; the low flyers, the type that can jump boats and obstacles and a wigtype that can make jumps way above its ground effect rite? attached an investigation on a hydrofoil wig with waterjet propulsion, fascinating. plz post your design, i'm sure i'm not the only one that likes to see it ![]() |
#102
| Take a look at this. http://www.lightsportaircraft.ca/vol...ue9/webcast-3/ |
#103
| Thanks Bruce46 I am aware of the Nelson, NZ design. Quite innovative but is it really a WIG? It appears to fly outside what one would call the normal permanent ground effect range and one would have to wonder if it is not legally an aircraft. |
#104
| Yipster I too would like to look at the design of rjbuljubasic@gm 's WIG craft Have to agree the video shows something similar to the Amphistar but with an extra wing similar to that of a normal aircraft - that wing doesn't appear to do much. It also appears to barely clear the surface and would not be suitable for marine conditions or choppy conditions. |
#105
| thanks for your input and the document about the massive wig plane design. I am busy with a animation video of my craft and should be completed soon the frontal stabilizer clears the water and should be at 1deg angle of attack at 170 knots fully loaded, this wing allows for straight and level flight at a wide range of operating speeds, but its main function is structural. About the choppy seas, NOT OPERATING IN THESE CONDITIONS, I am building this craft to work, I do not have enough money to build prototypes, this is why it is shorter than 12 meters, As to maritime law, I have to pass a float test, and I need to comply with a minimum speed of 5 knots. There are more regulations on the hanger where it will be built, than on the boat itself . |
| eletric ground for metal hull | luso | Metal Boat Building | 3 | 05-27-2006 07:40 AM |
| Combining WIG boats with downforce | Franklin | Boat Design | 3 | 07-11-2005 12:28 PM |
| How do I ground my electrical system? | jbassion | Sailboats | 13 | 04-27-2005 07:45 AM |
| Ground effect | Willallison | Boat Design | 15 | 02-08-2003 06:29 PM |
| WIG WWSSR Concept | foxxaero | Sailboats | 0 | 11-17-2002 02:55 PM |
