Old 08-16-2011, 12:40 PM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
student project - arrangement-Marpol
What are the differences between oil water separator and oil filtering equipment? when should i use them?
i need to know this for my project( thesis);
where do i find the firefighting equipment that i must install on board? Solas, FSS Code or Flag's instruction (ITALY).........
besides, what is the megger test that I often hear to speak ?
Many thanks in advance
Riccardo
Old 08-16-2011, 04:26 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Oil/water separators are installed inline with the fuel supply from the storage tanks, they are simply designed to, well, separate the water from the fuel oil. This is simply done by gravity, water falls to the bottom of the container, the fuel oil is taken from the top of the container. They also often incorporate a filter to reduce contaminants, rated in microns, such as 10 microns. This means that particles larger than 10 microns will be removed by the filter cartridge, but particles smaller than 10 microns will pass thru.
Oil filtering is another story. There are basically two systems, one for fuel oil, as stated above, but the other one is in fact engine oil, and it is engine oil that we refer to when stating oil filtering. It is done again with cartridges, the engine oil is pumped thru the filter under pressure and particles are removed , trapped by the cartridge. There are remote filter systems also, google Alfa Laval for instance to see centrifugal filters.
Try RINA for your fire fighting equipment lists.
A megger test is an electrical test done to confirm the resistance of an electrical cables insulation. It is measured in Mega Ohms...new installations are measured in millions , but that deteriorates in time, so by keeping a record of the megger test, you can determine when things are getting bad.
Old 08-16-2011, 05:01 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
http://en.wikipedia.org/wiki/API_oil-water_separator
http://en.wikipedia.org/wiki/Oil_filter
Hoyt
Old 08-17-2011, 11:12 AM
Rep: 749 Posts: 1,314
Hoyt; reference to the afrikaner/police problem is waaay off topic but it is an item of more than causal interest. I, along wth most Americans, was not aware of that kind of social unrest in SA.
Old 08-17-2011, 02:59 PM
Rep: 10 Posts: 73
Dear All
many thanks for answers;
Therefore is the OWS( oil water separator) that must be used on board in order to verify the annex 1 of the Marpol, is this true?
best regards
Old 08-17-2011, 06:09 PM
hoytedow's Avatar
Resistor
afrikaaner links are part of signature and not part of the topic discussion.
Hoyt
Old 08-20-2011, 02:57 PM
Rep: 10 Posts: 73
Landlubber thanks for answer;
Have you got any requirements for firefighiting lists?
Thanks in advance
Student Project Questions Tad Forum Questions and Suggestions 3 04-03-2010 02:56 PM
Student looking for degree project Lynndån Services & Employment 1 09-11-2008 07:31 PM
Amphibious Car Design - College Student Project mikehoyer Boat Design 18 03-23-2006 12:21 AM
Student boat project PSU_Mlt Open Discussion: All Things Boats & Boating 0 04-01-2005 12:40 AM
Student in need of project sponsor/mentor cappa2116 Powerboats 1 01-27-2005 12:01 PM
