Old 09-29-2008, 10:10 AM
netjaws netjaws is offline
Rep: 22 Posts: 73
Structural question
How would one calculate the maximum design working pressure of a tank in a tank barge, given section modulus, etc
Old 09-29-2008, 04:10 PM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 312
way too little information.
Sounds like you need a structural engineer, or experienced nav. arch.
Old 09-30-2008, 07:33 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
It sound like you are designing a ship to carry liquids. If so it would be no different than designing a pressure vessel, the density of the liquid times the depth (plus the safety factor) to get maximum design loads. If the "tank" is also part of the hull structure than you have to ad the hull loads on top of the tank loads, and consider it both empty and full (worst combination of loads).
This can be a very complex set of calculations depending on the conditions in which it will be used.
Structural Problem? dragonjbynight Boat Design 26 04-16-2008 12:26 PM
Structural Calculation lyqqmxm Boat Design 0 01-28-2008 06:16 PM
Structural design Javier Touceda Boat Design 0 10-31-2007 05:09 AM
A structural question ... ath Sailboats 10 06-10-2005 06:12 PM
Structural Joints Gone Ballistic Fiberglass and Composite Boat Building 1 03-26-2004 09:21 PM
