Old 10-12-2005, 07:43 PM
Harnesscreek Harnesscreek is offline
Stringers / Deck / Coosa BW26
I've be reading this forum and gotten a great education about rebuilding a C-Hawk 21. Thanks.
I was prepared to use marine ply epoxied together as the stringers and bulkheads then continue w. marine ply or MDO epoxied again as the deck. Recently discovered the Coosa Bluewater 26 product, though more expensive than marine ply, it seems one would save quite a bit of time, no impregnating all the wood w. epoxy. Just tab in the stringers epoxy the deck.
Epoxy would go from 5-6 gallons down to 1 or 2.
Has anyone used this product?
I'm not an engineer, is there something I'm missing?
Thanks,
Old 10-13-2005, 01:01 PM
gasdok007 gasdok007 is offline
Rep: 10 Posts: 24
ccosa
Ive only fooled around with this product a little- made a transom tansducer mount for an aluminum hull about 6 mos ago-still seems in good shape, but I sealed it in epoxy.Supposedly has little water absorbtion. I think hydra sports uses it as their deck material uncoated on the bottom. I tend to overkill, but I would probably seal this stuff against bilge water, but it almost certainly will take less epoxy than ply. Also its got alot of glass in it so be prpared to itch and go thru alot of blades or use some sort of diamond wheel to cut it.
deck construction Busted Knuckle Materials 12 06-26-2006 03:46 PM
Transom Repair with Coosa IHTFP Fiberglass and Composite Boat Building 0 10-06-2005 08:15 PM
Lifting a Deck steveo Fiberglass and Composite Boat Building 2 03-10-2005 09:18 AM
using composites in stringers and deck Guest Materials 13 07-19-2004 01:55 PM
Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! dan Boatbuilding 4 09-24-2002 04:48 PM
