Old 05-06-2005, 05:24 PM
chandler chandler is offline
Rep: 16 Posts: 378
Let's go back a few posts to #1. You live in B.C. Canada?
You're paying $11.00 a board ft. for douglas fir? Maybe you should take trip to the U.S and buy the fir grown in Canada in the U.S for alot less. You can buy old growth doug fir from Boulter plywood in MASS. for $7.95 a board ft.. That's taxachusset! In 20' lengths!
Old 05-06-2005, 05:29 PM
Rep: 16 Posts: 378
Originally Posted by gonzo
Polyester over wood works fine. The problem is when water gets under the laminate. Any screw or hole has to be either caulked or sealed. Most boats are polyester over wood and get a reasonable life.
I don't believe "most wooden boats" built today are polyester over wood is an accurate statement.
Old 05-06-2005, 05:30 PM
Rep: 16 Posts: 378
Old 05-07-2005, 09:42 AM
Ok J's Avatar
Ok J Ok J is offline
Ok J
Rep: 10 Posts: 25
Gussett blocks
G'day Cyclops
So what you are refering to is the area at the top of the stringer where it meets the transom, installing triangulated gussets perpendicular to the stringer that would attach to the transom. Yes the decking covers this area, the fuel tank will sit above this area once completed.
Mr Gonzo... I am mainly concerned about the deck plywood twisting (misaligning) over time as it previuosly had done, I suppose the main concern is supporting the joints where the floor joint will meet, and I thought adding bulkheads at these points couldn't hurt...however, that is why my question is in this forum. I have learned alot from those who have replied, and have made a few good decisions as a result...
thanks to both of you,...Ok J
the Sun is beaming here in the Okanagan today, must get busy!
Old 05-07-2005, 09:45 AM
Ok J's Avatar
Ok J
Rep: 10 Posts: 25
Thanks Chandler...we pay out the #*! for our own natural resources...The Doug Fir I am refering to is clear kd as well...not to worry, I found a better source.
Thx
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Stringer repair ?'s scarabfreak Fiberglass and Composite Boat Building 16 02-21-2007 11:00 PM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 08:29 AM
floor material crum731 Fiberglass and Composite Boat Building 4 08-19-2004 03:06 PM
